Question about Cell Phones
I can't pair my iphone 4s with my supertooth buddy
casouzaj
  • 1118 Answers
SOURCE: supertooth-light won't pair with new
Have you put your headset in pairing mode and entered the correct passkey, i.e. '0000' (four zeros)? Anyway, detailed instructions on how to pair it with your phone can be found on its user guide; In case yours happens to be missing, you'll still be able to find it here.
Regards, Carlos
Posted on Sep 29, 2010
EdNelson
  • 149 Answers
SOURCE: Hi I have a blueant
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devise's PIN number (often 0-0-0-0). Your phone should pair with the device then.
Posted on Jan 04, 2011
SOURCE: My nokia E71 will not pair up with the Supertooth
I had the same problem as you. I took the following steps to solve it.
- Powered off both devices.
- Turned on the Supertooth by holding the powerbutton until light alternates red/blue.
- Turned on phone, enabled bluetooth.
- Went to Connectivity->Bluetooth->(right)->options>"New paired Device".
It finally managed to pair the device.
Had to enter pincode (0000, which is default for all supertooths).
Hope it helps.
Posted on Jan 16, 2011
  • 943 Answers
SOURCE: Unable to Pair Samsung Galaxy Pro with Supertooth
it arises commonly because most of bluetooths cannot support more than one device(if once connected they dont connect to other device) ....
Posted on Oct 31, 2011
robert_wa291
  • 21 Answers
SOURCE: PAIR NOKIA C1 TO SUPERTOOTH BUDDY
Not all Bluetooth devices are compatible. I have had this issue with many of my phones and my old HFD's.
In evaluating this issue I see that both devices use BT 2.1 so there should be no conflicts with the communications.
Basic pairing steps can be done by going into your phone and making sure the following things are done:
1. Make sure your Bluetooth is turned on
2. Make sure your phones Bluetooth is set to discoverable
3. Place both the phone and the buddy within 5 inches of each other for optimal signal exchange
4. "From OFF, press and hold the On/Off (8) button of the handsfree kit until the Bluetooth Indicator (4) turns blinking red/blue. Then press the MFB (6)button to search your phone. Note: The handsfree kit will search only for 1 minute. If your phone is not found, press the MFB (6) button again." Supertooth Buddy User Manual
5. When the Buddy finds your phone accept any paring messages that appear on you phone and then your set to go.
There are manual paring instructions as well. Please refer to your owners/operators manual for further reading.
Source:
Phone - http://www.gsmarena.com/nokia_c1_01-3365.php
Buddy - http://www.supertooth.net/EN/BUDDY/#USER
Posted on Oct 15, 2012
How to pair supertooth buddy with my Iphone S5. Both are turned on but the Iphone keep moving on the circle to the right of devices?
To pair Iphone with SuperTooth Buddy it is required a PIN "0000". Also, push the button longer to connect devices
May 02, 2017 | Cell Phones
How to reset supertooth buddy
Disconnect the two devices from the speaker, turn off and on the speaker and pair and connect it with the new device.
Aug 26, 2014 | Supertooth Buddy Bluetooth Hands-free Car...
Pairing my phone with supertooth buddy
Thank you for using the SuperTooth Buddy. In case of problem please feel free to contact our technicians via our contact form http://www.supertooth.net/EN/CONTACT/
Best regards.
SuperTooth
Apr 08, 2014 | Samsung Cell Phones
My iPhone don't work with my Bluetooth speaker system
Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
Dec 22, 2013 | iLive Bluetooth Speaker System
Can't pair blueant bluetooth with iphone 4s
Open the device's microphone, ensue it is NOT on charge, hold the answer button and the silver flat button (hidden by mic when closed) and it should work
Nov 29, 2011 | Blueant Blue Ant 091193 Supertooth II...
Unable to Pair Samsung Galaxy Pro with Supertooth Buddy. Have reset both many times. Tried pairing via handset but cant seem to locate the Supertooth buddy when scanning. My Supertooth Buddy worked with my...
Oct 30, 2011 | Cell Phones
Bought a supertooth buddy to for use with my htc legend but it will not connect
Thanks for using Supertooth.
do the pairing as explained below:
Your Supertooth BUDDY must be in pairing mode before searching from the
phone.
1. From OFF, press and hold the On/Off button for 10 secondes until the
Bluetooth Indicator turns blinking red/blue. The handsfree kit is now in
pairing mode.
2. While the handsfree kit is in pairing mode, access the Bluetooth menu
of your phone. Turn on the Bluetooth function and execute a Bluetooth
search. (See your phone's manual.)
3. When the phone displays the list of Bluetooth devices, select ST
BUDDY.
4. If the phone asks for the password/pin code, enter 0000 and press Ok.
5. The handsfree kit is now ready to use.
Best regards.
SUPERTOOTH
Sep 25, 2011 | HTC Cell Phones
How do you pair an iPhone with the blueAnt st3?
Step 1: Activate Pairing Mode on the Supertooth 3
Make sure the Supertooth 3 is turned off.
You can tell if the Supertooth 3 is on or off by looking at the light on the front. If the light is on or flashing, then the Supertooth 3 is on: turn it off by holding down the Multi-Function button (the green button) for about 5 seconds, until you hear the voice announce that the Supertooth 3 is powering down.
With the Supertooth 3 off, hold down the Multi-Function button for about 6 seconds, until the light on the front of the unit starts flashing red and blue.
The Supertooth 3 will now prompt you to select your language: press the Multi-Function button when you hear your language spoken.
The Supertooth 3 is now in pairing mode.
Step 2: Apple iPhone
Now you need to use your iPhone to search for Bluetooth devices:
Select Settings.
Select General.
Select Bluetooth.
Wait for your phone to search for devices, then select your BlueAnt device from the list.
If you are prompted for a PIN, enter 0000 (four zeros).
Select Connect.
Your BlueAnt device is now paired.
Jul 12, 2011 | Blueant Supertooth 3 Bluetooth Handsfree...
My nokia E71 will not pair up with the Supertooth Buddy. The phone cannot seem to locate the buddy. the Bluetooth is on! Do you know why?
Hope it helps.
Jan 13, 2011 | Nokia E71 Smartphone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
