Why is my Defy Automaid 600 not spin drying when it has clothes in, but spins when empty?
5 Suggested Answers
SOURCE: defy automaid won't spin
Put the machine on its side and check the wires to the pump. i found one of the wires broke off the lug on the pump side. Could be from all the vibration from the drum. The machine will only spin if the drainage is working.
Good luck.
Posted on May 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: defy automaid runs through cycle but wont spin
It appears your Lid Switch/Door Latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
SOURCE: My Defy Automaid 600 does not dain the water out,
My defy automaid 600 does not drain the water. The pipes is not blocked.
Posted on Mar 26, 2011
FitzOriginal
  • 842 Answers
SOURCE: defy automaid - just stopped
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Posted on Jul 19, 2011
Defy automaid 600 making noise when spinning
Recommend contacting your local authorized service center directly or online here:
Request Service Defy
Feb 07, 2018 | Washing Machines
Why would my Defy 600 Automaid drum stop spinning?
The pressure sensor might be faulty. Something is telling the control that it is too full of water so the pump starts to empty it to avoid flooding. This is usually the water level or pressure switch.
See manual for your unit at this site.
http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
Pre
Sep 05, 2014 | Washing Machines
Hi, I own a Defy Automaid 600 and when I run a
Hello
Remove the detergent tray and look in to the top were the tray goes in there is a water dispenser there with a lot of hole check that non of those holes are not blocked, if so use a tooth brush to clean the holes.
Thanks
Jun 15, 2011 | General Washing Machines
Defy Automaid Washing Machine Model DAW265 - WONT SPIN Hi there: The machine runs perfectly through all cycles - fills up properly - drains perfectly - but will not spin at all [sounds like it is...
Possible fault of the program controller unit, the program output to the motor when the cycle is in the SPIN mode must be checked.
Make sure that the output is available, check using a multimeter to confirm. If absent then check the program module to confirm.
Jun 13, 2011 | Washing Machines
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
Defy automaid instruction manual how to use
click the link below for defy automaid manuals and instructions guide:
thanks and plse do not forget to accept the solution.
Apr 03, 2009 | Washing Machines
Defy automaid won't spin
Good luck.
Mar 10, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
