I need T CON BOARD For BAUHN TV 32" - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
Board number? For some peculiar trouble, it can be repaired. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Posted on Jan 04, 2017
Remote code for Bauhn ATV-BA32DV2
bauhn p v r setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... bauhn universal remote control tv but i had vivo tv how ican set up that The universal ... ATV-BA32DV2, have done initial setup, but screen says have to scan ...
Remote code for BAUHN TV model ATV-19HED - TVs - Home theatre ...
forums.whirlpool.net.au > Home theatre > TVs
WhirlpoolDec 14, 2014 - I've mislaid the remote for this TV and I was wondering if anybody new how I could get hold of BAUHN remote IR codes. I've looked everywhere ... 32" (81CM) HD LED LCD TV $222
May 29, 2014
Bauhn 24" Full HD LED LCD TV with DVD
Jan 12, 2013
More results from forums.whirlpool.net.au
[PDF]32" (81cm) HD LED LCD TV
Feb 03, 2016 | Televison & Video
My TV has vertical lines
hi,
Probably the t con board is faulty. first you have to check is there is any bad contact in the connections on the t con board. Remove and reconnect all the connections on the con broad. if the problem exist even after that you have to go for a new t con board . in some tvs 32 the t con board is not replaceable as it is integrated to the lcd panel.
check the video it will help you to identify the t con board
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
www.electro-medical.blogspot.com
Sep 25, 2015 | RCA Televison & Video
I have a Vizio E320I-A0 and it has multiple vertical and horizontal lines on the screen, how do i fix that?
Probably the T con board is faulty. T con board is the one which drives the lcd pixels. Chekc the video to identify the t con board. Also try to remove the connection to T con board and reconnect it. some times bad contact on those connectors can lead to such problems.
Sep 22, 2015 | Vizio E320i-A0 32 Class LED Smart TV
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
What is the purpose of tickon board in samsung 32
T-con board takes the serial video data from the main board and converts it to a format that the LCD panel will understand. The T-con also supplies power to the panel.
Aug 28, 2013 | Vizio 42 in. LCD TV
Hi my Sylvania LC320SS8 32 in LCD screen just turned all white with no picture, tv still has sound. The unit is only 2 years old. Is this the service life of the unit or what??
HI,
AS mentioned its sounds like the T con board of the TV is faulty. T con board is one which drives the LCD pixels. You can find this board on the bottom center of the TV covered by metal cover or aluminum foil. Replace this board will solve the problem. Its part number is BUF320G0401. I have found the same in ebay. But i am not sure is it working piece or not. Any way i have added the link.
http://www.ebay.com/itm/Sylvania-T-CON-Board-part-BUF320G04011-LC320SS8-/290602552500
Ajin
Dec 12, 2011 | Sylvania LC320SS8 32 in. LCD Television
Sylvania 6632LCT 32" the bottom
Vertical colors bars appearing and disappering are the causes by the board that call the T-CON board it is dying or the fiber optic cable that connected to it lose or damages internally.Mostly of the times about 99% of the times the T-CON board it is dying and it is not decodering pixels codes correctly anymore before it send those pictures pixels codes to the tv LCD screen panel.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-CON board for the replacement.
Jun 29, 2011 | Sylvania 6632LCT 32 in. LCD Television
I have a 32 inch MAGNAVOX LCD TV that exactly half of the screen has a gray or white film in front of the picture but the picture can still be seen behind it. The other side of the tv screen is perfectly...
This problem is the cause of the T-CON board is dying.This T-CON board sit at bottom of the LCD screen right in the middle of LCD screen.Change this T-CON should solved ur problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Sep 05, 2010 | SNK Magnavox 32MD357B_37 32 in. LCD...
I have a samsung lnt3253h lcd tv can you tell me the rating for the pico fuse on the t-con board and/or the part # for the t-con board assembly
Both chip fuses are 125mA 60V
This tv has two type of T-con boards, Click Type-1 and Type-2 to recognize what kind of t-con in your tv.
Thanks.
Aug 26, 2010 | Samsung LN-T3253H 32 in. LCD Television
Our picture on our Sharp LC-32AV22U 32 in. LCD TV fades to green and red and then it fades out completely. Does this indicate our tv tube is losing power?
It can be due to bad T-CON board or the main board is bad, you will need in-depth troubleshooting which will require service manual. Or you can try board swapping, starting with the T-CON board since it will be cheaper than the main board. If it needs the main board you may want to put the money toward a new TV instead.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 12, 2010 | Sharp LC-32AV22U 32 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
