Question about Samsung Office Equipment & Supplies
Samsung 4 error: A green Android picture saying Power reset or unknown upload mode.
It's a Samsung 4 android cell phone that has a error of POWER RESET OR UNKNOWN UPLOAD MODE
faggly
  • 74 Answers
SOURCE: Choked upload?
Hiya Masklin... go in to network connections... there will probably be 2 connections showing.. if you are the only user through your router.. disable lan 2.. trying to get two connections through same port.. which is more than likely at fault.
It will be the Ethernet connection that you need to leave enabled.. this should eliminate your problem ..
Regards Faggly
Posted on Mar 19, 2008
SOURCE: Can't upload data to computer
Summary: Memory of device overloaded.
1 Backup your Training center data under File in program.
2 On the device (using mode button) goto History [enter] go to Running or Biking [enter] click down to delete [enter] select "Keep 1 month " [enter] select yes for confirmation [enter]
3 Reinsert device in USB cradle. Select "Receive from device" under File in program.
4 Download your latest information.
Worked for me.
Posted on Oct 20, 2008
  • 276 Answers
SOURCE: Philips DVDR 3380 - display says''UNKNOWN''
if you get locked deconfigure this is that it can do is restart it from the inside has to find an IC that is the microprocessor and mandar grounding all pins
Posted on Aug 20, 2009
  • 67 Answers
SOURCE: When we try uploading things on to the internet
your internet connection might be slow . . . try different internet connection or wait for a day or 2
Posted on Jun 15, 2010
  • 9 Answers
SOURCE: Android: USB mode not supported when I have the Android plu...
Be sure your sync is on in your phone settings. From the home screen, press menu - settings - synchronization
Posted on Aug 05, 2010
Samsung sgh-t669 blue outline with red lettering saying SGH-T669 . QSC62XX More than Downloader V5.51 How do i fix it and make it start?
A few things,
1. The menu you are seeing is "Boot Mode" on most android devices it looks just like this, think of it like the control menu, or recovery mode screen on a Windows PC.
2. You can access this screen yourself, to put most android devices into boot mode you have to perform a hard reset to initiate this. To perform a hard reset, you want to simultaneously hold the power button, and the the volume down button for 10-15 seconds, after 10 seconds or so the phone will appear to power down and restart, as soon as the device powers off, and the screen lights up again release the power button, and continue holding the volume down key. You will then see the boot menu for android, from here the device should allow you to: 1. View your IMEI number, 2. restart the device normally,3. (this is how you root android phones, but I highly recommend not to do that, unless your experienced in jail breaking)
If you perform all said steps, you may have a phone that someone tried to root it, and didn't successfully complete the load of new software, which sadly makes the phones useless most of the time, and not able to save.
Nov 12, 2016 | Samsung Cell Phones
Icant open my phone because i forgot my password this is my imei **********63202 and **********63201
For android, 'Factory Hard Reset' through recovery mode and than Recover Data from your Backup Email Account.
Android recovery mode:
1. power off phone than
2. hold volume up, home & power keys at same time
3. release all 3 buttons when samsung screen flickers/appear with a warning
4. use volume keys to navigate to 'wipe data factory reset'
5. when done go back to main recovery menu, select reboot system now.
Now Enter your email address (used for backup) to recover data.
Hope this help you.
Aug 12, 2016 | Cell Phones
I have a virus on my phone and everyone is saying put it in safe mode. There is no safe mode on my android 4.2 phone
You didn't say which brand of phone you have.
Most phones about the same function wise. Here's instructions for Samsung phone.
Turn off your Android device.
  • Press the Power button to start your device.
  • During the startup, hold down the Menu button until the device starts into Safe Mode. ...
  • To restart the device into Normal Mode, turn off and turn on the device.
  • Dec 03, 2015 | Android Cell Phones
    How to unlock samsung E1272
    try this one If safe mode doesn't help fix your device, you can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down.
    Press and hold the correct keys to boot the device into recovery mode. This will vary from device to device. Here are some examples:
    • Nexus 7: Volume Up + Volume Down + Power
    • Samsung Galaxy S3: Volume Up + Home + Power
    • Motorola Droid X: Home + Power
    • Devices With Camera Buttons: Volume Up + Camera
    Similar devices will likely use similar key combinations. For example, the Nexus 4 also uses Volume Up + Volume Down + Power.
    If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery mode" - or look in the device's manual or support pages.
    Release the buttons when the device powered on. You'll see an image of an Android lying on its back with its chest open and its internals revealed.
    Press the Volume Up and Volume Down keys to scroll through the options until you seeRecovery mode on the screen.
    Press the Power button to restart into recovery mode. You'll soon see an Android with a red triangle.
    Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen.
    Select wipe data / factory reset with the volume keys and tap the Power button to activate it.
    Select Yes - erase all user data with the volume buttons and tap Power. Your device will be reset to its factory state and all your data will be erased.
    If your device freezes at any point, hold down the Power button until it restarts.
    If You Can Boot
    You can reset your Android phone or tablet normally from its Settings screen. Tap the Backup & reset option on the latest versions of Android or tap Privacy if you're using Android 2.3.
    Tap the Factory data reset option and to through the reset of the steps to confirm the factory reset.
    If the factory reset process doesn't fix your problems - or doesn't work at all - it's likely that there's a problem with your device's hardware. If it's still under warranty, you should have it fixed or replaced.
    (There's one exception to this: If you've been flashing custom ROMs and messing with your device's low-level software, it's possible that you could have overwritten the stock recovery software. In this case, it's possible that you have a software problem and not a hardware problem.)
    note all data will be deleted
    Apr 25, 2014 | Samsung SGH Cell Phones
    Unlock pattern
    tested 100% working How to Factory Reset Your Android Phone or Tablet When It Won't Boot android-recovery-mode.jpg
    Safe mode can help you troubleshoot your Android, but sometimes you'll need to wipe everything and restore your device to its factory state. You can even perform a factory reset when your Android phone or tablet won't boot normally.
    Ensure you have any important data backed up before doing a reset. This includes your Google Authenticator credentials, which will be lost during the reset. Disable two-factor authentication on your accounts first or you'll experience some trouble afterwards.
    If You Can't Boot
    If You Can Boot
    goodluck
    Apr 20, 2014 | Samsung Cell Phones
    Mi samsung exivit 2 stop to work it just don t turn on, in the scrim apear RAMDUMP MODE CAUSE ; FORCE TO UPLOAD.
    1. If your mobile is
    on, power it off.
    2. Press and hold
    Power until the
    device powers
    on, then
    immediately
    press and hold
    Volume Down
    (while still
    pressing Power).
    You will see the
    word Start with
    an arrow drawn
    around it.
    3. Press Volume
    Down twice to
    designate
    Recovery mode.
    4. Press Power to
    restart into
    Recovery mode.
    You will see an
    image of an
    Android robot
    with a red
    exclamation
    mark.
    5. While holding
    down Power,
    press Volume Up.
    6. Use the volume
    keys to scroll to
    "wipe data/
    factory reset"
    and press Power
    to select it.
    7. Scroll down to
    "Yes - erase all
    user data" and
    press Power to
    select it.
    Jan 29, 2013 | Samsung Cell Phones
    I forgot my password to unlock the galaxy y screen what i have to do?
    1. Power off phone
    2. Press and hold Home Button ( middle ) + Volume Up + power on button
    3. Wait for 5 second until Android System Recovery menu appear
    4. There are 4 options
    reboot system now
    apply update from sdcar
    wipe data/factory reset
    wipe cache partition
    5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode
    6. After the process done, phone will reboot.
    Jan 20, 2013 | Samsung Galaxy Y DUOS Android Smartphone
    How yo unlock my samsung galaxy young..
    1. Power off phone
    reboot system now
    Jan 20, 2013 | Cell Phones
    Unable to unlock my Samsung Galaxy GT S 5570
    if it is says too many pattern attempt ,your phone need to reset ...do this tricks ,...
    1. Power off phone
    2. Press and hold Menu Button ( middle ) + power on for at least 10 seconds
    3. Android System Recovery Mode Appear
    • reboot system now
    • apply sdcard:update.zip
    • wipe data/factory reset
    • wipe cache partition
    Sep 28, 2012 | Samsung Cell Phones
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
