It got stuck to spin and dry and does not want to reset to X press 14 min.
How do i reset my machine to start a new programme?
usually unplugging it for a few minutes should reset it/
Jan 04, 2017 | Washing Machines
How reset/reboot a HP Chromebook?
Press the Esc, refresh, and power buttons, at the same time., you should see a yellow ! mark. Then press Ctrl +D. ...Then press enter to begin...Screen shows a red ! mark, Press Ctrl+ D again, this deletes all local data and reboots your chromebook... It could take upto 15 min. to reboot. Ellen
on Jan 31, 2015 | HP Pavilion 14-c010us Chromebook 14-C010US...
My phone said needed updates to improve phone says will take ten mins pressed ok over hour ago now all i have is 2 spinning cogs
Generally when stuck, hard reset...
  1. Turn the phone off.
  2. Press and hold the power button. ...
  3. Another way to do this - press and hold the volume down button and connect the charger.
  4. Whit the exclamation mark on the screen press this sequence of keys:
  5. -> Volume Up.
  6. -> Volume Down.
  7. -> Power button.
  8. -> Volume Down.
Oct 07, 2016 | Nokia Lumia 630 Dual SIM RM-978
Perm Press cycle only runs for 2 min. and jumps to 14-15 min. every time.
find your manual and read it . sounds like the cycle has a 12 to 15 minute limit .
Feb 14, 2016 | Samsung DV330AE Dryer
Why is my washer stuck in the spin cycle
this might be too obvious but did you try to unplug the washer for at least 5 min to completely reset the computer in the washer ?
Jun 08, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Dishwasher will operate only 10 min before stopping cycle
Check for places food could get stuck and clog the workings, including the drain hose.
Nov 24, 2013 | Kenmore 24 in. 16302 Built-in Dishwasher
Clean button is flashing
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Spin Issues
Get manufaturer out under waranty,proberly moduale
Oct 11, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
