Question about Whirlpool Washing Machines
My washer has power, but when you press & hold Start, nothing happens. After a few mins, every light indicator on the control panel cycles through. The washer will not start in any mode.
Whirlpool Duet Washer WFW94HEXW2 I've managed to run the diagnostic test that starts at C00 and goes through each stage thru to C08. Everything runs fine. I've even killed the power to the washer via the circuit breaker to see if it would reset the control panel lights but still nada. When I was able to get error codes to appear, F05 flashes then E02 flashes. When I looked these up, they indicate an issue with attempting to lock the door 6 times without success thus the errors. I checked the door latch and it was loose, so I tightened it. The washer has been working fine until yesterday. Our washer has been unbalanced for awhile so we decided to adjust the feet. In trying to lift it up, the panel was pressed a few times by accident in addition to opening the door to get something to hold on to.
  • Jorge Rendon
    Jorge Rendon Jan 13, 2017
    Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
    MACHINES SAIDS SENSING
    When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
    will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
    added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
    NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
    Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
    Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
    This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
    I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
    Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem. If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
    A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
    The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
    The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
    God is good and that’s why I give free advice.
watugot
  • 290 Answers
SOURCE: Kenmore Elite he3 front load washer
What you describe still sounds like a door switch problem but if you can run it through the diagnostic cycle then it should be ok.
The only thing different in starting diagnostics and starting normal cycle is you don't press the start button in diagnostics.
If you know how to put it into manual diagnostics you can check all the buttons to make sure they are working properly.
It is unusual to have 2 different problems at the same time and if the switch was broken, it definately would not start the cycle.
Put it into manual diagnostics and check the start button.
Post back and we will go from there.
Thanks/Mike
Posted on Nov 03, 2007
SOURCE: Whirlpool Duet Washer - "Door Locked"
check wiring to switch.
Posted on Nov 01, 2008
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
  • 58 Answers
SOURCE: Frigidaire ATFB7000ES0 ERR PAU 3 beeps
An E-45 code is a control board issue & needs to be replaced
Posted on May 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Sport WFW8300SW04 frontload washer
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Dec 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    My washer won't start - :control lock" light is blinking but when I start the washer nothing happens help!
    press and hold the end of cycle button for 15 seconds and that should unlock the control panel
    Oct 16, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
    Hello
    first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
    normal wash ,, hi temp scub
    if either of these resets the control the you will have to replace the control panel / thanks
    Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
    I have a whirlpool duet HT. The control lock botton is on. So the washer will not start it does nothing. I unpluged it, hold in the unlock door botton nothing works. The door opens and close I just...
    Hello Welcome to FixYa here is the answer your searching for..Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked. If this was helpful please rate me Thanks :)
    Jun 12, 2011 | Whirlpool Washing Machines
    How do I use the Child Lock option on Samsung WF-B1456GW?
    You can use the child lock feature in 2 ways.
    1. To prevent operation of the washing machine when no wash cycle is running
    To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
    To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
    2. To prevent any tiny fingers from tampering with the machine while a program is running.
    After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
    The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
    Hope this helps. Please let me know if I can be of further assistance.
    Regards,
    BElectric
    Feb 09, 2011 | Washing Machines
    My duet washing machine is saying control panel lock out and nothing will come on. Any suggestions
    May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Control Locked
    Locking controls
    The Control Lock prevents unintended use of the washer. You
    can also use the control lock feature to prevent unintended cycle
    or option changes during a cycle. When CONTROL LOCKED is
    lit, all buttons are disabled. You can lock the washer while it is
    operating.
    To lock the controls
    Select and hold END OF CYCLE SIGNAL for 3 seconds.
    The CONTROL LOCKED status light glows.
    To unlock the controls
    Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
    Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    48 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
