Question about Garmin GPS
Cam I plug my garmin S2 charger into my i-phone wall charger unit ?
marcelbakker
  • 174 Answers
SOURCE: Garmin Muni 250 Battery problem
Try fully charging it, there is a small reset button on the bottom or behind the aerial....push that and try an restart it...then...webupdater
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Posted on Jul 23, 2008
  • 7 Answers
SOURCE: Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Posted on Sep 15, 2008
sharcnet
  • 2130 Answers
SOURCE: garmin wont turn on
Yes, it's possible to have damaged your GPS. I had a customer that sent me a dead Nuvi. I replaced the board and sent it back. As soon as they got it back, they said they plugged it into the charger and within a few seconds it died again. They sent it back to me and this time I asked for the charger. It wasn't a Garmin charger. It was a cell phone charger. It damaged the Nuvi again. So, I put in another board and sold them a OEM Garmin charger. Problem solved.
- Jim
SHARCNET-USA
Posted on Mar 16, 2009
  • 205 Answers
SOURCE: phone won't charge. when plugged into wall
your old battry boost for 6v charge 1 second try it now working or new samsung orginal battry use only other not working
Posted on Jul 13, 2009
tunde007
  • 2382 Answers
SOURCE: I have a Garmin Nuvi
Hi, from the detailed explanation you just gave concerning the charging issues with your Garmin, first of all plugging the Garmin and Sirius radio into a double prong jack adapter won't stop the Garmin from charging and secondly since you can still wall charge the Garmin, then there is nothing wrong with the device. So i suspect a faulty car charger irrespective of the fuse condition. Purchase a new car charger.....
Posted on Nov 18, 2010
Garmin nuvi 260 battery does not hold a charge
If a wall powered charger is used it could be bad or the connection from it to the unit damaged---happens if the charger is connected/disconnected a lot----same thing can happen if using the lighter plug adapter for charging.
Nov 06, 2012 | Garmin nuvi GPS
Battery power was low on my nuvi 255.plugged into the garmin wall charger.now nothing works.wont power up at all.plugged into the car charger and still nothing..whats happened ?
The 2xx series had a batch with bad batteries and they are replacing them even out of warranty , try your serial number on https://my.garmin.com/rma/recallLanding.faces. See if it is eligible for repair, if not the unit is probably pooched.
Hope this helps!
Dec 09, 2010 | Garmin Nuvi 255 GPS Receiver
For a 1450T garmin - do you have a home charger available?
we are not Garmin, but i can direct u to a site for a wall charger, this unit takes the same charger as the NUVI GPS's go to the link below. I assure u this is the correct charger for the 1450T as well
http://cgi.ebay.com/Home-Wall-Charger-AC-Adapter-Garmin-Nuvi-265T-265WT-/230532320323?pt=LH_DefaultDomain_0&hash=item35accc0c43
Sep 30, 2010 | Garmin GPS
Garmin c330 won't power on even when charger plugged in
Find the wall charger - most any usb mini that has the right out power amount [ do NOT over do it or you can burn the unit up] - Anyway - try the wall unit - if after 48 hours it refuses to take a charge - get a new one from www.tigerdirect.com for well less than the price of a battery.
Good luck
Gary
May 22, 2010 | Garmin StreetPilot C330 GPS Receiver
My garmin 765 T won't turn on- I have charged it overnight
If you are charging your unit with the USB cable STOP - use only a wall plug. The unit will not charge using the USB cable. If you don't have the wall unit - try charging it with the car plug charger for 15 minutes. Just let the car charge it running or not. You will see it work. Once it is charge over half way - the rest will charge up. It is a problem Gamin is working on.
May 05, 2010 | Garmin nuvi 765T GPS Receiver
My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
SHARCNET-USA
Mar 05, 2009 | Garmin Nuvi 760 Car GPS Receiver
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Am I able to charge Nuvi 205w with a standard cell outlet charger
For us, only the Nuvi car charger works - not plugging the Nuvi into a computer USB port, or using our Blackberry cell phone charger, both of which have the same type of plug.
Dec 28, 2008 | GPS
Garmin car charger
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
