Question about Bernina Sewing Machines
I am doing some machine embroidery on my Bernina Artista 730 and the upper thread keeps breaking. I have changed the needle and rethreaded many, many times!
    Top Expert:
  • Bernina Master
  • 50,572 Answers
Use a bigger eye in the needle and loosen of the needle thread tension a bit
needles are all the same length but come with various size eyes to accommodate thicker or thinner threads
use scrap material until you get a good combination
Posted on Jan 04, 2017
  • Thank you for your input. I changed the thread and didn't have the problem again. Same type of thread, but possibly just a bad/old/weak thread?
My machine keeps showing the bobbin error but there is nothing wrong in the bobbin
Assuming you have threaded the bobbin case correctly, you might try using a different bobbin. There may be something wrong with it. Make sure that there is no thread sticking out of the side of the bobbin.
If there is a bobbin thread sensor, it could be dirty causing it to not read the bobbin correctly.
When you thread the upper thread, be sure to ALWAYS RAISE the presser foot so the tension disk is released and the thread can seat properly.
Oct 11, 2016 | Bernina Artista 640E Sewing, Quilting and...
Bernina artista 185
try a new needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly
could also be a timing problem
Mar 05, 2014 | Sewing Machines
Thread bernina embroidery bobbin
The thread sensor eye is probably dirty.
Dec 26, 2017 | Bernina Sewing Machines
When stitching the design the upper thread keeps
The tension is not properly set for embroidery, try to rethread totally new. Sometimes it is also caused by broken thread inside the machine, you can open it with the supplied L-shaped tool on the left side of the machine where the lamp is located and than take it out with a tweezer.
Dec 21, 2009 | Bernina Artista 180
I must be threading my bernina artista 80 wrong it does not sew. I have rethreaded it a lot of times. what am I doing wrong now
Check to ensure that the needle is inserted with the flat side to the back.
Always thread the machine with the take-up lever in the highest position.
Consult the manual for exact threading instructions.
Jun 14, 2009 | Bernina Artista 180
Bernina 180 Artista sewing machine
you may have to replace the upper thread sensor
Apr 22, 2009 | Bernina Artista 180
Bernina 2500DCET serger keeps breaking the centre needle thread for no apparent reason .Already had machine serviced,new needle plate didn't solve anything either. Any ideas
I have found with any serger I have used that you have to cut the looper (bottom) threads before re threading the needle threads. You then rethread the loopers.
If you don't do this, the needle threads keep breaking. Hope this helps.
Mar 01, 2009 | Bernina 2500DCET
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
Embroidery
I had the same problem. It maybe you have some bits of thread caught inbetween the metal plates . That's what my problem was . Try cleaning carefully between the plates with something flat carefull not to scratch them.
Feb 25, 2007 | Bernina Artista 180
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
