Powerfit E380 Vibrating Platform just beeps when turned on.
Powerfit E380 Vibrating Platform just beeps when turned on.Why??
3D Silk Eyelashes 3D Silk Eyelashes The Sample is Free And Can Fast Delivery Wholesale most popular premium individuals 3D Silk Eyelashes with private packaging.Our 3D Silk Eyelashes Price cheap and Directly sell from Our manufacturer.Our 3D Silk Eyelashes can wear 20-25times and is soft,luxury,elegant,and natural.If you want know more ,you can contact us.
May 08, 2018 | Platform Computers & Internet
Stop it from vibrating
bad counter weights
Feb 23, 2015 | Washing Machines
E380 won't power on
it can be anything, check first power cable, power supply or motherboard check if any beep?
Aug 24, 2014 | Computers & Internet
Hi i have an acer aspire E380 and it doesnt boot up when switched on,it doesnt even beep. noce rare occasions it with work fine but it may take many attempts. what could be the cause many thanks.
Your problem is either with your power supply or motherboard, but being as it boots somtimes and then dosent, and not even a beep, then the power supply would be the main cause, i sugest taking the power supply out of the computer and taking it to your local pc store, ask them if they could test it for you before you buy a new one. hope this helps.
Jan 30, 2010 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
I can't get my Acer aspire e380 to accept another
How many slots for RAM in the motherboard?
If there are 4 slots, are the slots equally-spaced, or are they located as two pairs of slots, with a gap between the 3rd and 4th slot?
Some computers _REQUIRE_ RAM only in the 1st and 3rd slots, or only in the 2nd and 4th slots.
Some computers "beep" when 3 out of the 4 RAM slots are populated.
Some computers require the size of the RAM in the 1st slot to match the size of the RAM in the 3rd slot,
and the size of the RAM in the 2nd slot to match the size of the RAM in the 4th slot.
Does your computer "beep" when one stick is in the first slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the second slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the third slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the fourth slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the first slot and a matching stick is in the third slot, and the other slots are empty? How much RAM on those sticks?
Jan 23, 2010 | Acer Aspire E380-UD420A (ASE380-UD420A)...
VGA No Signal. Tower will not boot up. Continually beeping
Oops if you have a continually beeping bios it's extremely likely that there is a fault with the Power supply unit and this will need replacing which is easy enough
Oct 21, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Computer beeping on startup
One long, two short is the POST beep code that indicates something is wrong with your display adapter (e.g. your video card).
Make sure your video card is plugged into your computer firmly. If it is an onboard card, you may need to get an external video card and plug that in to test if that is your problem.
Feb 01, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
