Question about Tefal Irons
I have a tefal 5375 aqua speed iron and there is a constant red light on, what could be the problem. Thank
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
geokohler
  • 304 Answers
SOURCE: Not getting hot
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
ginko
  • 19396 Answers
SOURCE: tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Posted on Apr 22, 2009
  • 60 Answers
SOURCE: not heating up, flashing light
It sounds like you have a loose wire, check your plug to make sure the wire connections are sound. The loose connection may be where the wire enters the iron its self. For saftey I would have this repaired by a professional or have it replaced.
Posted on Dec 04, 2009
SOURCE: how can i clean my tefal iron/ surface
tough soapy sponge
Posted on Dec 27, 2009
I have a tefal pro express turbo GV8150 and there is constant team coming from iron without me touching the steam button. Can anyone help with a diagnosis and or possible fix?
constant steam means the control valve is not working
descaling may fix the problem
the other fix is a new iron as the cost to repair is generally more that a replacement price
Sep 30, 2016 | Tefal Irons
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
My tefal express 2941 steams constantly when switched on and cannot be stopped, please advise?
Fill the iron with 50/50 water and vinegar and let it steam for as long as it will. This will clean out the iron thoroughly, the green light will stop flashing and it will go back to normal. Then remember to clean your iron on a regular basis. Mine did!! Found this solution on another site
Feb 20, 2010 | Tefal Irons
My tefal aqua is not taking out creases but i can see steam coming out of the iron I have tried the instructions according to the manual for cleaning but still no good please help
Some creases cannot be removed with any steam iron.
Dampen the area with the creases or place a wet press cloth over the area and try again.
Feb 20, 2010 | Tefal Aquaspeed 170 Iron
Red light on
element is shot,take it back or send it back for repair
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal iron stopped working
You better open your tefal iron,so you can fix the problem.When open look for the contact bronze in color must them place in the center,use a sandpaper to clean the contacts,when already clean test it if its okey going to hot again if not turn the udjuster to adjust it is a screw liked.
Hope it nay helps you;
Apr 22, 2009 | Tefal Aquaspeed 155 Iron with Auto...
Red light on
Per the owner manual, you shake the iron to "wake it back up".
The safety cycle initiates after it sits over 8 minutes on it's heel, or on it's sole plate or it's side side for more than 30 seconds. The light shoul dbe blinking when it is in the safety mode.
If you can't wake it up, then return it if it is still under new warranty.
Jan 30, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal Pro Express - Constant Steam (Model 2932)
Great answer from Jacquief above. To which I add try giving the base of the iron and its button, a very light tapping with a tack hammer (much smaller and lighter than a standard hammer) wrapped in a tea-towel. This can often break up the lime scale seal which has formed somewhere inside and is not responding to Jacquief's method. In future never use scale laden tap water in your iron, use $2 litre bottles of distilled water from any supermarket.
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
Insufficient steam
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Feb 18, 2008 | Tefal Aquaspeed 170 Iron
Irons Logo
93 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
