Question about Troy Bilt 5.5hp Self Propelled Mower
Self-Propelled Model Starts, then dies after about 15 seconds
The mower is new -- bought earlier this summer. It ran fine the last time I used it, 2 weeks ago. The oil level is fine and it has a full tank of new gas. Since I started having this problem, I have to prime the mower at least 15 times to get it to start at all. The engine revvs up full throttle, runs for about 15 - 45 seconds, then dies. Then I have to prime it 15 more times to get it to start again. Every time I get it to start, it dies after 15-45 seconds. Someone suggested that I try cleaning the air filter, but I don't know where the air filter is.
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Posted on Jul 25, 2009
  • 227 Answers
Your owners manual should tell you where the air filter is. It could also be a blockage in the gas tank at the fuel pickup point. Also check for a leak in your fuel lines. Many movers these days also have fuel filters if yours has a filter I would suggest replacing it. If all else fails the mower is under a year old you may have some kind of warranty coverage still in effect.
Posted on Jul 21, 2009
Lawnmower Makes Squealing Sound when Self-Propell is Used
if you take it apart there will be no warranty . take it to where purchased and get it repaired
Jul 21, 2015 | Troy Bilt 5.5hp Self Propelled Mower
Husqvarna self propelled lawn mower
Fuel problem. Disconnect fuel line from carb. No fuel, go up the line. Filter, open line, plugged fuel cap vent.
Jun 26, 2013 | Garden
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
22 In Craftsman Self propelled.Starts easy, runs good for about 15-20 mins. Starts missing and dies. Will start again in about 30 mins New spark plug/ air filter
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Aug 05, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Starts but wont keep running
The fuel bowl has a float and needle, the bowl is filled with gas and over time the float gets filled with gas or just don't float as it should within the bowl. the needle is pulled up by the float which lets fuel flow into the carb. A repair kit can be bought for $5 and is easily replaced. After you take this apart, it's a good idea to clean the carb with a carb cleaner. You'll have to take off quiet a bit which looks difficult but it's really not.
May 03, 2010 | Poulan Pro " Pro" Self Propelled Mower
Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Aug 27, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Mower starts but boggs down and then dies
Sounds like the air filter media is full of muck.
You need to clean it.
Everything should then be fine....
Jul 01, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Under load the engine sputters and backfires.
I had the same problem; The first 2 years the engine ran fine and then the third year it started backfiring, so I put a new carburetor on my engine and the same thing happened. The real problem was the valves needed adjusted. Yes I know, this is very rare, but it did happen. I decided not to try this adjustment myself and opted for a mower shop to do it. It cost about $50.00 and the engine has been fine ever since.
Mar 21, 2009 | THQ The Lawnmower Man
Troy Bilt 5.5hp Self Propelled Mower Logo
1,137 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
