Question about Lands Phones
When my car is shut off my pldnv695 unit still shows screen with circle arrows number 1234. What do I do?
Tip
NOKIA-THE REBOOT TRICK
<p>This should work on all software versions of the 6110.<br /> <p>1. Go to the Calendar (Menu-8)<br /> <p>2. Make a note or reminder.<br /> <p>3. Enter some text into the edit box.<br /> <p>4. Hold "Clear" until the whole text is cleared, then press "Back".<br /> <p>5. Press "0". The main screen will now be showing but a space appears on the screen. (you can't see it)<br /> <p>6. Enter 4 digits (e.g. 1234).<br /> <p>7. Use the down arrow to move the cursor to the left side of the numbers and the space (Down arrow twice).<br /> <p>8. Now enter 6 digits and press the call button.<br /> <p> <br /> <p>Wait for a few seconds, the screen should start to flash and reboots. It should alsowork on other menus like the "Profiles" menu.<br /> <p> <br />
on Jul 27, 2011 | Cell Phones
Tip
Mobile Phone Tips & Tricks:
<p><b>THE REBOOT TRICK</b><br /> <p>This should work on all software versions of the 6110.<br /> <p>1. Go to the Calendar (Menu-8)<br /> <p>2. Make a note or reminder.<br /> <p>3. Enter some text into the edit box.<br /> <p>4. Hold "Clear" until the whole text is cleared, then press "Back".<br /> <p>5. Press "0". The main screen will now be showing but a space appears on the screen. (you can't see it)<br /> <p>6. Enter 4 digits (e.g. 1234).<br /> <p>7. Use the down arrow to move the cursor to the left side of the numbers and the space (Down arrow twice).<br /> <p>8. Now enter 6 digits and press the call button.<br /> <p> <br /> <p>Wait for a few seconds, the screen should start to flash and reboots. It should alsowork on other menus like the "Profiles" menu
on Jan 30, 2011 | Cell Phones
When i turn on the car the radio doesnt go to the home page it goes to a screen with circle and arrows number 1234
You have the unit wired wrong. When you shut your key off the radio loses ALL power and it needs ACC power to maintain the memory. If not, the unit will reset itself. The screen you see is the touchscreen calibration screen. Just follow the " X " around the screen to 5. Then the unit will boot up again. You will have to reset radio stations and EQ and speaker settings. If you don't fix the ACC wire, you will have to do this A LOT!
Dec 06, 2013 | PYLE Audio PYLE PLDNV695 6.95 DOUBLE-DIN...
Once a week at 4:00am my GE Simon XT does an auto phone test. At 4:12am it notifies me that the phone test has failed by beeping continuously until I press disarm. How do I get the system to stop running...
You will need the installer code to change the setting. Factory default is 1234. press the up or down arrow until "system programming" appears on display. press "OK" and "enter code" appears. Enter installer code. If it accepts it, "access codes" appear on the display. Use the down arrow until "timers" shows on display. Press"OK". Press the down arrow until "auto phone test tm" appears on display. Press" OK". use up and down arrows to adjust to "off". Press"OK". press "Status" and "timers" is shown. Press up arrows until "phone numbers" is showing on display. Press "OK" press "OK" again press "disarm" press "OK" press "Status" 4 times. You have now completed removing the phone number and turning off the phone test.
Nov 21, 2012 | GE Security Simon 3 Wireless Home Security...
How to reprogram n5610d-1
Jun 30, 2011 | Nokia 6288 Cellular Phone
Hi.. please help i have a pioneer hard drive dvr-520H. i love it and have never had any problems over the years. but just yesterday it froze up on me when i was trying to watch a recorded show. now when i...
Those circles are there as a sign that the unit has not finished loading the indicator - it's a wait signal. This happens because the processor no longer recognizes the indicator for the shows you recorded so yes, this is a big defect.
The unit is repairable - you will have to replace the hard drive and reprogram the unit - but this is a long and costly procedure. It will be cheaper just to buy a new one.
Mar 11, 2011 | Pioneer DVR-520H DVD Recorder
What is the firing order on a 2006 mercury mountaineer where can i get apicture
V-8? 13726548 with number 1234 from front to back on pasenger side. draw a box, 4 holes on the right side of page and 4 on the left. these will be your cylinders. now draw an arrow in the middle indicating the front of the vehicle. on the right side with the arrow facing away from you, label the cylinders from the tip of the arrow rearward 1234, and you got it, label the cylinders on the left 5678 from tip of arrow rearward.. theres your picture
Jun 17, 2010 | Cars & Trucks
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Please help remove the on screen display of channel number
what is your TV type and model ... some TVs show the channel No. by defualt and can't cancel it ... please rate me if you find this helpful
May 29, 2007 | Jensen JR300 Remote Control
Lands Phones Logo
27 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
