Question about Gateway Computers & Internet
Windows won't read SCHC card
I have a Gateway 5034gt. To my understanding it only reads SD cards, not SDHC. Is there a firmware update anyone knows of to be able to use it?
    Sergeant:
  • 280 Answers
If you're using the SDHC card with a mobile phone or a portable media player, chances are that, the device would have formatted the card to its requirements, which renders it non-readable under windows. To view the contents of the card, you'll need to insert it into the device and connect the device to your PC.
Posted on Jul 21, 2009
How can I get the card reader to recognize sdhc cards
It's not your card reader, the SDHC mini firmware is dead that's why your reader cannot detect it. Warranty, return it to SanDisk for a new one. Every hardware you plug or attach to a PC or Laptop has what is called a firmware, a mini program that communicates with your PC and Laptop that's how they syst
Dec 30, 2012 | Gateway GT5082 PC Desktop
Gateway desktop can't read a sdhc 32gb memory card
well it should read it unless the reader is incapable of reading cards of that capacity.. Are you sure the card is good ? try it on another reader..
A firmware update wont be of any help there since the capacity is HARDWARE not software. If the card is good you will need to replace the reader to a newer model or acquire and external card reader.
Dec 29, 2012 | Gateway Computers & Internet
My gateway computer won't read my 32gb sdhc card
If your current card reader isn't compatible with SDHC cards then you need to get one that is. While SDHC cards fit into the SD slot, they care electronically incompatible and won't work in devices not designed for them.
Dec 29, 2012 | Cameras
What is the largest size GB SD Card this camera will be able to accept? I just purchased an 8 GB & the camera reads a card error....I am guessing it can not handle an 8 GB...?
The DMC-FZ7 is designed to work with SD cards up to a maximum 2GB capacity (4GB in theory, but very few devices work reliably with the 4GB SD as they simply didn't exist at the time so could not be compatibility tested with most SD devices). You have tried an 8GB SDHC card which the camera is incompatible with.
The SDHC card is the same size and shape as SD but is significantly different "under the hood". SDHC compliant devices can use earlier SD cards, but devices which are not designed to use SDHC cards cannot be updated: the incompatibility lies at the basic hardware level so there is no firmware update to overcome this.
So your guess is correct, but I hope that my reply helps you to understand why. Your fix is therefore to stick with SD cards of a maximum 2GB capacity. As SDHC cards start at a minimum 4GB capacity, you have no risk of buying the wrong model.
Please take a moment to rate my answer.
Sep 22, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
My sd card reader wont do anything when i put in a card what can i do to fix it ?
Replace the card reader, it has died - it happens. Luckily this is a cheap fix.
Apr 11, 2010 | E-Machines eMachines Desktop PC
SanDisk ImageMate 12in1 cannot read SCHC 4GB or higher cards
Correct!!!! This card reader cannot address cards that are higher then 3gig and cannot read sdhc cards. Most older readers will not be able to read the HC type card, and by older I mean if its 6 months old or more. To read these cards you need to purchase a new card reader. I know, My camera uses 4gig cards and I was unable to access the pics until I bought a new reader..
Dec 02, 2009 | Computers & Internet
My toshiba laptop doesnt read SDHC card
sdhc cards are not backwards compatible with sd card slots. sd cards however are backwards compatible with sdhc card slots. newer card slots and readers are sdhc and sd ready but i'm afraid your only option is to buy a usb sdhc card reader. normally the 52 in 1 readers and ones like that work well and really don't cost a lot on ebay. the only other thing you could try is to put the sdhc card in an sdhc device (such as a camera) and link it up to the laptop that way.
Apr 04, 2009 | Toshiba Satellite M115-S3094 Notebook
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
Computers & Internet Logo
245 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
