Question about NetGear Computers & Internet
INSTAL PASSWORD TO NETGEAR 74 MODEM ? - NetGear Computers & Internet
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Dont know how to install a password so other wireless computers cant log on I have a netgear WGT624
    Hi dude check this would be useful
    http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf
    Things You'll Need:
    • Ethernet cable
    • Cable or DSL modem
    • WGT624 Installation CD
    1. 1 Plug the Netgear WGT624's AC adapter into a wall outlet. Plug an Ethernet cable into the yellow Ethernet port on the back of the Netgear router. Attach the other end of the cable to the Ethernet port on the back of your modem.
    2. 2 Insert the installation CD that was included with the Netgear WGT624 into your computer's disc drive. Click the language option you want to use and then click "Setup."
    3. 3 Follow the setup wizard's onscreen instructions and then click "Finish." The wizard will automatically detect your Internet settings. Open a web browser and navigate to "http://192.168.1.1."
    4. 4 Type "admin" in the Netgear's "User Name" text box and then enter "Password" in the text box labeled "Password." Click "OK."
    5. 5 Click "Yes" and wait for the latest firmware upgrade to install. Double-click the upgrade file and follow the onscreen instructions to install the upgrade.
    6. 6 Click the "Wireless Settings" link if you want to password protect your wireless network. Click the "WEP" radio button and then type in the password you want to use for your network in the "Passphrase" text box.
    7. 7 Click "Apply" and then close the web browser.
    Sep 27, 2010 | NetGear WGT624 Wireless Router
    How do i hook this router to my laptop?
    Things You'll Need:
    • Ethernet cable
    INSTALL CD
    No install CD needed with valid working internet with modem. First you need to turn off your computer then connect the working hsi modem to the Netgear router with the ethernet cord (looks like a thicker telephone wire) connect the ethernet cord from the back of the modem to the first single port on the Netgear not the ports labeled 1-4. Then with another ethernet cable snap one end into one of the 4 ports available and the other end snap into your computers ethernet port. Then unplug the MODEMs power cord for 30sec plug it back in wait for modem to boot back up with all of its lights and turn the computer back on. After install is finished you can now go and download your routers firmware from Netgear. In your address bar where it reads http://.........go ahead and highlight this and backspace it all until it clears to blank. Type in 192.168.1.1 and then hit enter. A window will pop up asking for username and password. For username type in "admin" for password type in "password" this is default and will always work unless someone has changed the username and password already on your home network, in which case contact netgear support. But if it does work the you will get Negear Smart Wizard. Here is where you can click on "Setup Wizard" and follow the prompts to download latest firmware and then Finished. Close down the netgear page and happy wireless internet surfing.
    Apr 25, 2010 | NetGear WGR614 Wireless Router
    I have BSNL broadband with Siemens SL_2 141 modem provided by BSNL. I want to connect it wireless with my desktop. I also have a Netgear WG111 v3 USB adapter. Please suggest how to install the wireless...
    First get IP of Siemens SL_2 141, start- run -cmd- ipconfig /all
    Note down Default Gateway IP address ( Generally 192.168.1.1)
    Type it in Internet Explorer address bar and hit enter
    put username admin, pass admin
    Click Wirelles then in Basic setup, Enable Wireless, Enter SSID as BSNL, transmission mode 802.11g, then remaining option as auto, do not keep security now let it be disabled, click apply or save and rebot the router.
    Install Netgear software in ur desktop let search for ssid BSNL and connect automatically. Once connection gets establish then set security WEP-PSK and put password also in Netgear u have to mention same password whil connecting.
    More help here page no 97
    any query revert,
    Thanks
    Sep 05, 2009 | Computers & Internet
    About 108 mbps wireless router wgt624 netgear
    HOW CAN I INSTALL MY NETGEARN 108Mbps WIRELESS FIREWALL ROUTER WGT624 v2.
    Jan 23, 2009 | NetGear CG814M Wireless Cable Modem...
    Difficulty in installation
    1. hard reset ur modem ( it will set to bridge by default)
    2. connect ur modem to WAN port at netgear router
    3. connect ur pc to LAN port at netgear router
    4. by default ur pc ip should be 192.168.1.x
    5. type at IE/firefox address bar
    username = admin
    password = password
    6. enter all basic info (ISP = other, streamyx username password, wifi setting)
    7. set value for idle timeout (in minutes) = 0
    Dec 18, 2008 | NetGear WGR614 Wireless Router
    My Roadrunner Modem works fine when connected to an individual computer. When connected through my netgear modem I cannot get an internet connection on any computer wired directly to the router
    does the modem worked fine with ANY computer connected directly to it, or just ONE computer connected to it?
    did you have to install a connection program on one of your computers when you first installed the modem?
    do you have an account name and password from your internet service provider, which is required to connect?
    Mar 24, 2008 | NetGear WGR614 Router
    Netgear WGR614
    First thing I did with my Netgear is this.
    Plug in the dsl/cable modem to the PC directly. Then install the driver on the cd. If you are one of the unlucky types like I was, the router didn't come with a cd. Try going to Netgers page see if they have a driver. Most are basically auto install. Try this before you check the netgear site though. Plug in the cable/dsl modem to the router and the pc to the router. Resstart everything. This includes the modem, router and pc. When it pops back up, try seeing if that works. if not, try opening up Internet explorer. Type this in to the url. 192.168.1.1 or 192.168.1.0
    That should bring up the netgear setup page for the router. If it ask for a password, the password on mine was
    username - admin
    password - password
    It has an auto configure tab so click on that and that should automatically take care of everything for you. Let me know what happens!
    Feb 27, 2008 | Computers & Internet
    Computers & Internet Logo
    64 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
