Fe error in wirlpool? - Washing Machines
How do i reset FE code on wm2016cw washer machine
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced
Oct 16, 2014 | LG WM2016C
Fe warning light
Fe error code means "Water Overflow Error". Check the upper level sensor of the machine.
Dec 22, 2013 | LG Washing Machines
Samsung washing machine
Based on my experience, the same thing happens to me as you have mentioned that it happens every end of a cycle. I doubt if it was a fan error or a frequency error. for me, its just a simple overload for the autodrying. for example on my model. the manual says autodrying cotton-cupboard dry must be max 3 kg. since you cannot measure your wet clothes and it sometimes exceed the 3kg autodrying, that is when the FE comes out. but when i remove some clothes or spin the laundry again and put it into drying, everything works fine. when i use the machine with minimal clothes say 2kg dry, the whole cycle up to drying work fine without FE errors.
So i believe its just an error for drying overload. also the manual says nothing about FE nor Error code for drying overload.
Hope this help.
May 31, 2012 | Washing Machines
My wirlpool dishwasher tab compartment don't open through the wash cycle
Clean it out with boiling water, soap residue is making it stick. The compartment is opened by heat during the wash cycle.
Dec 23, 2011 | Dishwashers
My wirlpool range says EO F2 and will not turn on and none of the buttons work. What is wrong?
That error means you have a shorted keypad. Check the keypad connector for firm connection (keypad connects to control board). If thats ok, Press CANCEL. If the error code returns after 60 seconds you will need to replace the keypad.
Aug 19, 2011 | Whirlpool Kitchen Ranges
I am getting fe error after the water fills in.it doesnt start washing. What to do?
The FE error isn't common to all washers. In fact, I could only find information on it in relation to LG washers. I actually found this link here which explains it pretty well:
http://www.managemylife.com/mmh/questions/208013-lg-wm2032hw-error-fe
Jun 23, 2010 | Washing Machines
FE ERROR CODE
FE error is due to "Over flow" error. Water is overflowing (water level frequency is over (213) When FE is diplayed the drain will pump out automatically. Water level sensor needs to be replaced.
Apr 09, 2010 | LG WM0642H Front Load
2 year old elect range/oven by wirlpool will not
check your input voltage your probably losing a leg and only have 120volts instead of 240 volts that would cause a reduced heat symptom
Jul 16, 2009 | Ovens
Olympus FE-5010 Card cover open error. Card cover is closed. Tried a new battery and new card. It didn't help.
i hv olympus fe 5010 nd problem is "write protect" error sawing .....so how i cn solve it
Jun 27, 2009 | Olympus FE-190 Digital Camera
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
