Question about Westinghouse Dishwashers
I have a Westinghouse Virtuoso 922 and the top propeller came off and it looks like it just fit onto the top rack, is that righrt
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso fridge- my top panel has gone blank - and everything in my fridge is now freezing - is there an easy solution to fix this ??
Sounds like the thermostat has failed to on and the machine just keeps freezing. Before replacing the panel try turning the power off to the fridge at the wall for 2 minuites and then return the power.
Apr 05, 2014 | Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Rack and pinion steering lines on 98 ford explorer pressure line and return line witch one on top
the return line is only held on by clamps at both ends or one end at the rack assembly,even though the fitting it connects to may have a nut fitting that threads into the rack.the pressure line always has fittings at both ends that can only be fastened onto the pump and rack by a wrench(or line tool).
Mar 24, 2011 | Ford Explorer Cars & Trucks
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Dishwashers Logo
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
