Question about Kohler Home
Unclipping collet a kohler sink hose - Kohler Home
4 Suggested Answers
  • 349 Answers
SOURCE: crack in farm house undermount sink Kohler
Possible you could use an epoxy or J B Weld to repair it. I have fixed a couple of gas tanks with JB weld it should work on Cast also . It not to expensive and may be a start for you.
Posted on May 05, 2010
  • 122 Answers
SOURCE: Will Kohler Disposal Flange K-11352 work with Kohler Sink K-5924?
Kohler makes their sinks standard, and most all sinks are the same size hole, yes it will fit.
Posted on Aug 06, 2010
SOURCE: brand new kohler cruette. attached cold and hot water fine. when snapping in the pull out faucet hose it sprays all over under the sink
Hi rysenga, the problem is an omission of directions. The section 9 directions are the worst offender and left me never again to purchase a Kohler product. First, this connection for the pull out hose to the outlet fitting should have been a screw on connection. Should have been. Ok it was not, I'll get over it. But the directions never mention having to install the white plastic bushing. Not at all. Nor does it mention that the bushing should be put on the outlet first and then push the hose connection in. This omission is a huge one, but should help anyone else reading this complete the install. Find the oval lip white bushing and install this first on the body, and then just push the connector in. Done.
Posted on Nov 17, 2012
How do I disassemble a Kohler kitchen faucet
Remove sprayer and hose from faucet body.
Remove handle and cartridge.
Pull up on body.
Replace parts and reinstall in reverse order.
Aug 31, 2014 | Kohler Model 10433: Fort® Single-control...
Replacing hose on a Kohler model numbe K- 10433
http://411plumb.com/kohler-forte-faucet-troubleshooting-repair-guide/
Mar 11, 2014 | Kohler Model 10433: Fort® Single-control...
How do I replace a hose diverter in a single handle Kohler kitchen sink?
Yes, contact Kohler and they have a site you can watch that should be helpful.
Jan 11, 2013 | Kohler Home
Kohler Coralais
Check under the sink to be sure the weight on the hose isn't resting on something, preventing it from retracting fully into the base. Also check to see if the weight might be in the wrong spot on the hose and not pulling the faucet back into the base properly.
Aug 30, 2012 | Kohler K-15160-7 Coralais single-control...
May 22, 2010 | Kohler Plumbing
Trying to find basket strainer for Kohler vast
all of kohlers baskets fit their sinks, even older model sinks.
do you have a special strainer, or sink?
have you contacted Kohler direct? or one of their distributors. a wholesale plumbing supply house (NOT lowes or home depot) in your area will be able to help you also
Oct 15, 2009 | Kohler Plumbing
Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
Apr 21, 2009 | Kohler Model 10433: Fort® Single-control...
Low flow from Kohler K15160 spray kitchen sink faucet. If I take off the spray handle I can fill a jug through the hose alone (including the filter screen) in 15 seconds while with handle on the same...
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
Mar 01, 2009 | Kohler Coralais Black Single-Control...
Kohler 5988 Sink leaks from soap dispenser spout (?) when dishwasher is running
Hi.. Its a breather or "vent "and its clogged. Remove the drain tube under the sink that runs from the vent to the connection on the drain( under sink). Clean vent and replace. Please send me some Positive feedback if I've help. Thankyou!
Jan 21, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Home Logo
106 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
