Question about Epson Aculaser C1100 Printer
Reinstalling previously used cartridge
As a studying mechanical engineer, I thougt I would be able to solve our companies printer problems. But I just took out the blue cartridge to check if it was correctly installed. Now I am trying to put it back but I cannot lock it. Is there a mechanism that needs to be resetted when you want to lock a previously unlocked cartridge? Or should I just push it very hard (I am actually afraid it will break)?
Thanks for your help.
  • Epson Master
  • 691 Answers
Re: Reinstalling previously used cartridge
Make sure you are trying to insert it with the carousel in the correct position. Use the printers driver to rotate the carousel to the correct position. Slide the cart in level and push it well home.
If it will not lock properly, bin the cart and replace it. If you put a cart in that does not seat right you run the risk of spreading toner all over the inside of the machine and the clean up is a bigger job than buying a new cart.
Ensure the carousel is in the right position - the tram lines the cart slides down MUST line up perfectly.
Posted on Dec 07, 2007
0 characters
3 Points
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
My printer Brother DCP 165C cannot print in black ink.
Your black printhead is blocked.
The printhead is deep inside the printer and has to be taken out by the expert and cleaned with the help of 'steam' and hot water. This is because not using the printer for a long time. or using low grade refill inks.
Please select new cartridge only if you are inserting a new cartridge or fully refilled cartridge. Otherwise use old cartridge option. Brother printer has a mechanical sensor and not the electronic chip in the ink cartridges.
After inserting the old used cartridge if you choose 'new cart' option it will show the "Full" ink. You can still print from the exhausted ink cart after covering the sensor in the middle by a piece of paper in emergency.
Mar 01, 2010 | Brother DCP 165C Compact Color Inkjet...
Error 1203 Dell 926 All in One Printer. I have cleaned the printer heads with a damp cloth, and switched the printer off and on
Please try reinstalling your ink cartridge. If won't work go to properties on the printer, maintenance, and align the cartridges from there
Jeep Brainy
Aug 14, 2009 | Dell 924 All-in-One InkJet Printer
Printing light and blurry. Changed in cartridges
try reinstalling the driver of the printer. if problem still persists, then you need to check the mechanical parts of the printer. also check if the power lines are good. try restarting the printer and take out the cartridges, if it prompts for an error, then turn off the printer again and install the cartridge. If problem still persists then you need someone to open it and check the mechanical parts or the main board of the printer.
Aug 07, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer 4270 prints only a partial page and then stops
Thanks for the help. I followed your recommendation of uninstalling the Lexmark program and reinstalling it. Note that I had done this previously and still had the problem. However, following your advice, the third time must have been a charm. The problem has been solved.
Feb 04, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error on :Lexmark x6180
did you remove the tape that is on the cartridge. look at the area touch the paper path, see if there is orange or red tape on the cartidge. pull it out and insert the cartridge again. it should work
if the answer solve your porblem. please rate the answer.
thank you
Oct 14, 2008 | Lexmark X6180 Printer
Canon i965 error message 'The used ink tank is full.'
I have same problem. Have tried both solutions but neither have worked. Anyone have any other ideas?
May 10, 2008 | Canon BubleJet i965 InkJet Printer
Canon pixma ip4500 print head problem 5 lights flashing. Reinstalling print head does not solve problem.
Printhead can be washed under running hot tap to flush all the old ink away. I did mine and it didn't affect performance after drying it overnight in a warm area. Re-fitted it and away it went. Don't worry about getting connector board wet at the back.
Apr 17, 2008 | Printers & Copiers
Epson Aculaser C1100 Printer Logo
66 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
