Question about Sewing Machines
Taff Deluxe Zig zag - Sewing Machines
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at
Posted on Feb 24, 2008
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
  • 65 Answers
SOURCE: No "Zig" to my "Zag"
I Love the support Brother gives!
Here's what Brother says about the Zig zag issue.
your manual (download)
Posted on Jan 27, 2009
  • 46 Answers
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Posted on Jul 27, 2009
  • 2976 Answers
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Posted on Aug 28, 2009
How can i find a manual for a universal sewing machine kzm 022951
Universal Sewing Machine Product Support ...
Just aquired a universal sewing machine model Kzm. Universal Sewing ... Needmanual for Universal AZZ Super Zig Zag sewing machine. Universal Sewing ...
Universal Zig-Zag Deluxe sewing machine w/ manual ...
? 4:06
Oct 28, 2013 - Uploaded by hindsight80
Universal Zig-Zag Deluxe sewing machine w/ manual. I just cleaned and oiled it it is ready to go. Awesome ..
Nov 05, 2015 | Sewing Machines
Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
Aug 01, 2012 | Husqvarna Sewing Machines
Dressmaker zig zag deluxe s3000 doesnt pick up bobbin thread
it's possible that a gear is broken or worn a sewing machine shop can tell you exactly
Feb 20, 2012 | Sewing Machines
I'm sewing a zig zag stitch and the underside is a perfect zig zag and the upper side looks like it should be the can I fix this so that the beautiful zig zag is on the top?
FIRST > Make sure your bobbin case is threaded correctly...
For normal straight sewing the top tension should be around 5, for zigzag or satin stitch you need to lower your upper thread tension a bit. Try it at 4, if it still pulls your bottom thread to the top try it at 3 etc...
Jan 15, 2011 | Euro-Pro Deluxe 7130 Mechanical Sewing...
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
