Question about Bosch Washing Machines
The rinse cycle of the bosch front load nexxt series washer 100. how to fix it.
  • Bosch Master
  • 5,323 Answers
Could u explain more what is the problem
Posted on Jan 05, 2017
How to replace a drain motor on a bosch nexxt 100 series washer
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Mar 18, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Nextt 100 frnt load washer wont go past rinse cycle..stops with drum full of water..i cleaned the pump area filter and drain hoses and upper cannister thoroly..whats nexxt??
It can be the program controller unit. You need to check the output to the program controller unit to confirm if the power comes out to the next cycle. Start by following from the inlet opening vavle, the cut off and the motor drive to confirm.
Please see these tips: Repairing Washer
Jun 28, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washer will not complete a full cycle.. when on rinse does not finish beeps as though it done but is still on rinse..also fabric softner does not drain into machine. machine will spin if I manually set...
my washer does not finish a full cycle ;but is still on rinse and its a bosch and i was wondering
were is the fuses kept in the machine,
sandra read
sandrarread@yahoo .co uk
Jan 22, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Front loading washer does not advance past the rince cycle
Check and clean filter, it is usually located behind a plastic panel at the bottom front of the washer, remove cover and unscrew the filter cover anti clockwise, pull out and clean, replace and test, if it still does not drain, then possibly pump blocked or faulty.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Dec 20, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
