Question about Bosch Washing Machines
The bosch front load nexxt series 100 rimse is just flashing will not go off and the waher will not unlock.
  • 1294 Answers
SOURCE: Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Posted on Dec 21, 2007
  • 130 Answers
SOURCE: Lots of mold and mildew stains on front door seal.
Easy, try running a cup of white vinegar thru the wash cycle. I sell and fix these and it usually work everytime. good luck
Posted on Jan 24, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
barkencoa
  • 3463 Answers
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Posted on Mar 15, 2010
  • 1075 Answers
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Posted on Jun 29, 2010
How to replace a drain motor on a bosch nexxt 100 series washer
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Mar 18, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer wont spin belt is on pump is free of debris
Possible that the main motor is jammed or does not get power from the program controller unit. It is important that you measure the voltage at the motor when the program is set to start after the inlet valve fills water. If there is no voltage then the program controller unit is faulty.
Click this link for support : washing machine tips
Jun 25, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
My bosch 100 nexxt will not spin or complete a full cycle
does it spin and no pump, or pump and no spin or neither does it come to end of normal wash and stop before spinning.
Dec 21, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
How I can clean fliter for washer machine bosch nexxt 100 series
just unscrew the filter plug located usually front bottom of machine.
Dec 13, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hello - we have a Bosch Nexxt 100 Series Washer. The front loader door is locked and I cannot get it to unlock. We have a load of clothes in the washer. I have tried to run the "spin" cycle...
Easy to do....But may need a service call from a pro to fix the underlying issue.
Take the bottom right little door off and try not to cut yourself reaching in..(OH TURN OF THE POWER). reaching in after looking with a flashlight try to grap the zip tie looking plastic hanging there and pull it down gently and it will unlock.
Of course make sure you tried to unplug it first for 10 minutes and then try turning it on again in spin mode.
Thanks,
Jan 31, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 100 series will not drain
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt series washer - water in softener dispenser
Hi. Remove dispenser, and thouroughly clean.
This should solve problem. If problem persists, don't worry about it tomuch, as long as it takes the conditioner down that is the main thing.
Nov 23, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing Machines Logo
23 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
