Question about Sewing Machines
I cannot get the upper thread to pull up the bobbin. I have changed the needle.
  • Sewing Machines Master
  • 11,500 Answers
If you've installed a new needle, then most likely the machine is out of time. Search for sewing machine timing or take it for service.
Posted on Jan 04, 2017
The upper thread won't catch the bobbin thread and pull it up
This is a symptom of wrong timing between the hook and needle in your sewing machine. Try to pull up your bobbin thread by setting your needle to the left and then to the right. If it will bring up the bobbin thread whiled set to the right but not the left you have a timing problem. It can be corrected by a pro but it most likely will need to have some gears replaced also.
Dec 16, 2017 | Sewing Machines
I have a janome 8200, when sewing the top stitch is perfect but top thread bunch under neath and no bobbin thread appears to be used, I have changed threads, bobbins and needle,
Be sure to use a brand new needle.
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread the upper thread. This allows the tension disk to release so the thread will seat properly. Verify that the thread path is correct.
Check that the bobbin is installed correctly (turning the proper direction in the bobbin case) and the bobbin case tension is threaded correctly.
Set the upper tension to the midway point. (This is the beginning point and may need tweaking later.)
Pull the bobbin thread to the top of the sewing project.
How and Why to Bring up the Bobbin Thread P.S.--this works with regular sewing, not just for quilting.
Lower the presser foot and test your machine. Begin sewing slowly.
If there are still issues--upper thread looping, try tightening but if it doesn't improve, the tension mechanism may not be working properly. Check and remove any thread pieces or gunk stuck in the tension mechanism. If still not working, it probably needs service.
If the bobbin thread is still not connecting with the upper thread, the sewing machine's timing is most likely off. (Search the internet for "sewing machine timing." There are multiple web sites and videos available that discuss this OR take it for service.)
Oct 08, 2016 | Janome 8080 Computerized Sewing Machine
When i lower the needle to pull up the thread from the bobbin it feels like theres tension like thread pulling tight and the needle will not go all the way down. It stops. I see no thread anywhere.
Is the upper thread pulling tight when you move the needle? If so, there is something holding it back--perhaps it is incorrectly threaded or the thread is hanging up in the tension disk.
Remove the upper thread completely. RAISE the presser foot and then rethread from the beginning making sure that it is threaded in the correct sequence (check the owner's manual).
Set the upper thread tension to somewhere around the midway point between the high & low number.
Then retest.
If it continues to be a problem, you might try installing a new needle and changing out the thread.
If you can observe the needle from the bobbin area and the needle is actually hitting something, then it is most likely out of time and needs to be serviced.
Feb 16, 2016 | Sewing Machines
How can I prevent bobbin thread from bunching up and tangling?
First thing to do: install a brand new needle and clean the lint/dust from the feed dogs and bobbin area. Make sure you are using the right needle and thread for the fabric being sewn.
All About Needles
Second thing: remove all the thread from the machine. RAISE the presser foot and rethread from the beginning making sure that it is threaded correctly through every thread guide (consult the owner's manual). And verify that the bobbin is loaded and threaded in the bobbincase properly.
AVOID using old, fuzzy, and bargain bin threads.
Set the upper tension to the midway point between the high & low number (this is the factory standard although every machine may slightly differ). Now perform a new stitch test.
If the upper thread is creating a thread mess under the fabric, the upper tension is too loose. Tighten it.
If the bobbin thread is coming up to the top of the fabric, loosen the upper thread and retest. Sometimes the upper thread tension is not enough to prevent the bobbin thread from coming up. In that case, the bobbin tension may need to be tightened. (Search the internet for instructions for adjusting the bobbin tension. NOTE: bobbin tension adjustments should be done in micro-increments as a small adjustment will make a big difference in the result. Be sure to test after each adjustment.)
The tension is correct when the upper thread and bobbin thread meet and cross in the middle of the fabric. This will change whenever fabric, needle & thread are changed, so a sewist needs to be comfortable with regularly making upper thread adjustments.
One other thing to try is pull the bobbin thread up through the fabric before stitching and gently holding the thread tails when taking the first couple of stitches.
Jan 25, 2016 | Sewing Machines
The bobbin thread shows to the front. Does the bobbin or thread tension need adjusted
Generally, tension adjustments are made using the upper thread tension. Most likely the upper tension is set too tight and is pulling the bobbin thread up. Loosen the upper tension and try again. Tension is accurate when the upper thread and bobbin thread meet in the middle of the fabric. Whenever fabric, thread & needle are changed, there may be a need to adjust the upper tension.
HINT: When threading the upper thread, make sure the presser foot is RAISED during threading to make sure the upper tension disks are open and the thread seats properly.
Bobbin tension is only adjusted when the tensions are way out of whack. Only slight turns of the bobbin case tension screw are made in graduated movements and testing occurs after each adjustment.
Jan 20, 2016 | Sewing Machines
Need manual my tension is out I think the bobbin is also faulty
search the manufacturer's website or Google make,model,manual
Dec 15, 2015 | Sewing Machines
Model 230. Why is it losing the thread at the needle everytime I sew?
The thread sounds like it is not running freely so the upper tension is either too tight or blocked by lint.
If neither of these solutions work then try changing your needle as a blunt or wrong needle can also be a cause
Nov 29, 2015 | Consew Sewing Machines
My viking emerald 118 machine just started breaking needles and the bobbin thread will not hold. YOu can pull the bobbin stitch out by pulling the thread.
Check the upper tension by lowering the presser foot and pulling on the thread through the needle. You should feel resistance. If not, take a stiff brush and clean out the tension disks/dials removing any loose threads or lint. If upper tension is ok, check bobbin tension by pulling thread through needle plate opening. You should feel resistance. If not, remove bobbin case and brush any loose threads or lint from the case, especially in the tension spring where the thread is snapped into place. You may need to use a sharp needle to dig in between the spring but be careful that you don't damage it.
Jun 17, 2014 | Husqvarna Viking Emerald 116 Sewing...
Jamming or timing at bobbin
The bobbin case should be loose enough to wiggle a little. Take it out and look for needle strikes or damage on the edges, if it is damaged you can try to smooth it up with fine file as a temporary fix but purchase a new one soon as possible. The other two factors to look at is the upper thread take up lever, make sure the thread is in it and then check the upper tension by pulling thread thru the needle. When the presser foot is in the raised position, the thread should pull thru the needle easily, when the foot is lowered onto the fabric, the thread should be hard to pull. If it is still easy with the foot down then the thread did not go into the tension discs properly or the upper thread tension dial is set at too low a number. It should be on a 3-4 or 5kif I remember correctly.
May 27, 2010 | Janome 6260QC Computerized Sewing Machine
My machine is a Brother XL5600; I think I am having a shuttle hook problem. When I lower the sewing needle to "catch" the bobbin thread and pull through- it won't catch and pull through. I have changed out...
Thanks for using FixYa. The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine according to the directions in the manual.
Place a spool of thread on a spool pin and check the upper threading.
Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
Also please check that the bobbin is installed in its case rightly. Needle thread is too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted and install a new needle with the flat side of the needle facing the back.
Please do rate the solution and revert for further assistance.
Sep 26, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
