Question about Sanyo SR-3660S Compact Refrigerator
Small refrigerator freezes everything
My Dynasty R450-C compact refrigerator has turned into a freezer. When I turn it on a low level (or any level) it will go down to 20 degrees, and freezes everything in the refrigerator. It has a small freezer built in. Can I replace the thermostat, and if so, where would I look for the part?
    Problem Solver:
  • 5 Answers
Adjust its thermostat. or if its broken try getting it fixed. if not then you just have to buy a new one :D
Posted on Jul 21, 2009
How to adjust the thermostat
Hello Keith Wertheim,
Your freezer MAY-BE SET to COOL or your food might be blocking proper AIR-FLOW... CHECK these FIRST before
SETTING ANY CONTROLS...
Set freezing level first... (close below freezing)
THEN set refrigerator levels last...
(very close ABOVE freezing)
- Before setting ANY MILK, MEAT and/or VEGETABLE
CONTROLS are set to MIDRANGE...
The ENTIRE APPLIANCE should be ALLOWED TO
STABILIZE (run un-molested) for 24 - 72 hours BETWEEN ADJUSTMENTS.
PATIENCE works the best/fastest...
My apologies just because this has become a GLOBAL site... I'm TYPICALLY an unapologetic Fahrenheit (°F) kind of guy. Since this is actually a GLOBAL site
32 DEGREES is freezing point in Fahrenheit (°F)...
((WIKI conversion discussion at VERY BOTTOM)).
>> Depending one what refrigerator you HAVE...
And... your personal preferences...
Your refrigerator is set very CRITICALLY ABOVE
32 Degrees Fahrenheit (°F) = FREEZING...
but below 40 degrees
(for safely/longevity)
((Don't care about Celsius/Centigrade or Kelvin)).
Your owners manual directs you though SET-UP.
(all that is available on-line as well by searching your model+owners+manual).
Once you are SET-UP (level, square) ...
TEMPERATURE "SETTING" it is a bit of a balancing act
(I recommend you buy 2 ( refrigerator + freezer ))... between the freezer hardness (LARGE range of operation) and the REFRIGERATOR (very SMALL range of operation)
FREEZER working range -20 degrees up to FREEZING.
If it is "A Thermostat" one compartment will necessarily have to follow the OTHER... In MOST cases you simple DETERMINE
WHAT LEVEL OF HARD-NESS you FIRST WANT in your
ICE CREAM... (freezer adjustment first).
INTERESTING...
I have JUST DISCOVERED... a new TWO EVAPORATOR
design ... More fun.
Kelvin Wikipedia the free encyclopedia
Jun 12, 2016 | Refrigerators
Tip
How to fix a leak inside a refrigerator
Turn off the refrigerator. Remove the rear panel and floor cover from the freezer. You will see a lot of ice covering everything. Remove/thaw this ice.
In the back of the freezer, under the coils is a drain. When the defroster runs and melts the ice on the coils, the water is supposed to run down the drain to a pan where it is evaporated by a fan under the refrigerator. Often, this drain freezes shut. Then, the water has no place to go but though the vent into the refrigerator.
Melt the ice in this drain with a hair dryer or small quantities of hot water. You will know the drain is clear when the water level suddenly drops. Finish drying everything in the freezer and replace the panels.
Now, you will no longer have water dripping inside your refrigerator.
on Feb 06, 2010 | Refrigerators
Will not turn off. Thermostat control clicks but refrigerator continues to run in the off position and therefore will freeze everything inside.
Check for a small wire sometimes copper color that ends in a small bulb in the refrigerator. Then check to make sure this sensor is not unplugged from its source. This if the thermal sensor that measures temp in the refrig
Nov 04, 2013 | Haier HSA04WNCWW 3.9 Cu. Ft....
The freezer section of our Danby DFF8200W freezes well. However, periodically the refrigerator section freezes everything in it with the temp control turned as low as it will turn for me. The dial does not...
Make sure you clean the backside of refrigerator at bottom from dust. Make sure you have the recommended clearance from wall. Also make sure the food in freezer and frige have clearance to allow air to circulate around food. Keep playing with your controlls...The dails might be on wrong
Aug 11, 2013 | Danby Refrigerators
Model#1051 small dorm size...doesn't matter where i set thermostat..it sill freezes everything,,,suggestions?
Repace thermostat. You didn't tell us that it runs ALL the time. It does. You don't have to tell me, I know it does. The first thing the power does is go thru the thermostat and its job is to turn the power off to the pump when it gets cold enough. If it gets cold and freezes everything then everything else is working right. There is no fixing the old thermostat either. That little tube that looks like a heavy bare wire ending next to the freezer coil has a little "freon" in it that expandes and contrectes with temp. change and the change in pressure is what ativates the thermostat. Chances are the "freon" leaked out.
Note, this is not the same "freon" that is pumped around the fridge to cool things. This is sealed in the thermostat and tube only.
Jun 23, 2011 | Goldstar GR131CN Compact Refrigerator
My chefmate RS 06DR is freezing everything
temp should be38-40 degree F the tub is for ice maker
Aug 14, 2009 | U-Line 15R Compact Refrigerator
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Continues to freeze
It sounds like the temp sensor isn't working properly and letting the compressor run all the time till it freezes. If you are "handy" you can replace the temp sensor. Parts are available online at different websites like repairclinic.com or partselect.com, etc.
Feb 26, 2007 | Danby DAR482BLS Compact Refrigerator
Sanyo SR-3660S Compact Refrigerator Logo
451 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
