Question about Hisense Televison & Video
Want to know center to center measurment of legs on Hisense 65CU6200 to see if it will fit on a 48 wide table? Thanks
    Top Expert:
  • Hisense Master
  • 75,417 Answers
It won't fit to this table. At least 40 foot wide table needed.
Posted on Jan 04, 2017
Testimonial: "Did you mean 40" or 4' surely that was a missprint 40'?"
Will the Hisence 65cu6200 tv fit on a 48"x 18" table?
it will stick over on both ends by 12 inchs
Jan 03, 2017 | Televison & Video
Tip
All purpose presentation easel a DIY project
You never know when you are going to need or want an easel to show off your art work, maybe your kids want to finger paint who knows they could be the next Van Gogh. Building a display easel is very simple and can be done in just a few hours.
You want to start with two pieces of wood cut to 2x82" these pieces will form the front legs of the easel. Using a table saw cut the tops of the wood to a 15* angle. Take a measuring tape and measure 78" from the bottom of the wood (up to the angle cut) mark this spot on both pieces.
Using a drill, drill a 3/8" hole through the widest side of the angle as a right angle to the cut. Repeat for the second front leg.
To make the back leg cut a piece of wood down to 2x81" long, using your drill, drill two 3/8" holes in the widest side of the wood. One hole should be 39" from the bottom of the wood and the second at 74" from the bottom.
Your art work needs something to sit on so to make the cross bar cut a piece of wood down to 2x47".
Now you are ready to assemble your easel. Take the front and back legs and lay them on the floor next to each other with the back leg in the middle. Rotate the front legs to the angle is facing the back leg and line up the holes. Slide a bolt into the hole and place a washer and a nut on the end, keeping it loose enough to adjust the angle. Stand up the easel and spread the from legs so that they are 45" away from the back leg. Tighten the bolt and you have the angle right and lay it back down.
To attach the cross bar, measure 38" up from the bottoms of the front legs find the center and drill a 3/8" hole in each and bolt the cross bar to the legs. To keep the legs from spreading too far you can attach a chain between the cross bar and the back leg. To do this you thread the chain through the hole in the back leg and tie it off. Attach an eye screw to the cross bar and loop the chain through it to keep limit how far the legs can spread to the angle that you want to work or display at.
on Jan 29, 2014 | Office Equipment & Supplies
How can I make a really cheap sofa table?
Cut ListCut List: A) 4 - 1x3 @ 29 1/4" (Fronts and Backs of the Legs) B) 4 - 1x2 @ 29 1/4" (Sides of the Legs) C) 2 - 1x3 @ 10" (Side Support) D) 1 - 1x2 @ 37" (Stretcher) E) 2 - 1x3 @ 37" (Side Trim for the stretcher) F) 2 - 1x4 @ 10" (Side Apron) G) 2 - 1x4 @ 37" (Front and Back Apron) H) 1 - 1x12 @ 48" (Base for the top) I) 2 - 1x4 @ 11 1/2" J) 1 - 1x12 @ 41"
Step 1
Download Original]'>untitled-3%20(15).jpgConstruct your legs by nailing through the 1x3 legs into the edge of the 1x2 legs with 2" nails and glue. The legs will be positioned with the 1x3s to the front, 1x2s to the side, as shown in the diagram.
Step 2
Download Original]'>untitled-4%20(14).jpgStart by marking each of the legs 5" from the bottom of the board. This will be the bottom of the side support, C. Nail C to the legs, using 1 1/4" nails and glue, from the inside.
Step 3
Download Original]'>untitled-5%20(13).jpgNow add the stretcher, D, centering D on the support, C, but keeping the top edges flush. D will lay flat, with the wide side up. This is demonstrated above. Use glue and 2" nails, nailing through the support, C, into the end of D.
Step 4
Download Original]'>untitled-6%20(9).jpgAdd the side trim pieces, E. First, nail through the supports C into E, using 2" nails. Then nail down the length of the stretcher, taking care to keep the top edge of the stretcher (D) perfectly flush with the top edge of the stretcher support (E). Use glue and 2" nails.
Step 5
Download Original]'>untitled-7%20(8).jpgNow use the 1 1/4" nails to nail through the back of the side apron pieces, F, into the legs. Use glue. Keep top edges perfectly flush.
Step 6
Download Original]'>untitled-8%20(7).jpgDo the same for the front and back apron pieces, G, as shown above. Nail through G into the legs using 1 1/4" nails and glue. Keep top edges flush. Take a minute to check for square
Step 7
Download Original]'>untitled-9%20(7).jpgNow add the base top, piece H. Keep the front and back edges flush with the legs, but let the sides overhang 4" on either side. Nail into the legs and the apron using 2" nails and glue.
Step 8
Download Original]'>untitled-10%20(6).jpgUse glue and 1 1/4" nails to attach the breadboard ends to the base top. Keep all outside edges flush.
Step 9
Download Original]'>untitled-11%20(5).jpg I recommend not cutting the final piece, J, unitl you have taken an exact measurement. Add the final piece, using glue and 1 1/4" nails.
Finishing Instructions
May 29, 2012 | Furniture
What is the distance from center of metal mounting bracket to center of other bracket for 24 inch ceramic Glacier bay towel rack
Put the towel rack together setting on a table and measure the distance between the two mounts.
make sure you know where the mounting bracket fits into the ceramic peace's.
Feb 03, 2011 | Home
Will this bike fit me my inseam is 32"
Measure the center pipe from the sprocket to the seats mounting hardware stem. Allow 5 inches for the legs to pedal so the center frame bar must be 27 inches or less for you to ride this bike correctly
Apr 07, 2010 | Schwinn Midmoor Men's Hybrid Bike
I want to know what stove I have?It is a fisher, doulbe door, width is 29`` depth is 26`` , height is 30``.
Double door Fisher is if the Fireplace Series. Pre 1980 stoves had the angle iron welded up the side that became the legs. Grandpa Bear measures 29 1/2 wide and takes up to 24 inch log. Grandma Bear measures 25 1/2 wide, and takes 20 inch log. AFTER 1980 the legs were short and did not extend up the stove corners to top. They were Grandpa Bear III and Grandma Bear III. Very close to the same sizes.
Dec 21, 2009 | Sport & Outdoor - Others
97 fxdl, difference between narrow/wide glide componants
You need the complete front end including the wheel. The FXDWG is somewhat of an oddball in that a lot of parts fit only that bike. A lot of other parts will not fit a Wide Glide. This even applies to the exhaust system.
Measure the diameter of your upper fork tubes, they're 39 mm tubes. The Wide Glide uses 41 mm tubes. The Wide Glide also uses a 21" front wheel.
Nov 08, 2009 | Harley Davidson FXDL Dyna Low Rider...
Does any one know if progressive shocks off a 1997 dyna wide glide will fit a 2003 dyna wide glide.
They should fit, just measure the length of the shock from eyelet to eyelet. if you don't have the measurements of the other bike just call a local dealer to find out the standard length
Jul 22, 2009 | 2003 Harley Davidson FXDWG Dyna Wide Glide
Trying to figure angle for six leg circle
I'm not sure what a six leg circle is but a circle has 360 degrees, so if you want to divide it into six parts, each triangle has an angle of 60 degrees at the center, and 60 degrees at the other two angles, so each combined angle of the inscribed hexagon is 120 degrees. (That's measured in degree, not reading off a chop saw.)
Hope that helps...
Apr 18, 2009 | Saws
How wide is the rear cargo space in a Chevrolet HHR Panel
it's not that wide. i rented one a year ago to drive home from the airport. while it was a pretty cool looking vehicle it only impressed me as much as a cavalier or cobalt does. it's not that wide in the rear. it might fit, but i'd check to see if there's specs online or stop by your chevy dealer. the HHR is not a work vehicle. you're better off with an s-10 or colorado.
May 15, 2008 | 2007 Chevrolet HHR Panel LT New Cars
Televison & Video Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
