Question about Garden
My hunter sprinkler system has a very weak display screen. Battery replaced with no improvement. Digits and letters can not be read but with missing parts to the display.
  • 9098 Answers
SOURCE: Microwave display - digits have become dim / partialy missing
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
Full details and *critical* safety, disassembly, and troubleshooting info is at Web our site, which is linked at our listing here on FixYa:
Posted on Nov 18, 2007
  • 1723 Answers
SOURCE: Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Posted on Jul 02, 2009
  • 704 Answers
SOURCE: Sprinkler System reads PR OFF
You need to reprogram your timer, as whenever you change the batteries, several maker's timers lose the program you've put into them. The PR OFF means the Program is turned OFF and you must re-enter the start and stop times and day(s) you wish to have the sprinkler system runnning.
Hope you find this Very Helpful and best regards.
Posted on Aug 25, 2009
SOURCE: Nelson traveling sprinkler broken plastic part
I just took mine apart about a week ago. If, I recall correctly, you broke the T piece. That black plastic or nylon nut that is still connected to the transmission should thread off fairly easily.
I expect you can buy the part from Nelson.
If, solution #1 is correct and you find you cannot get the part, I've done some truly amazing repairs with that epoxy product called PC7. Depending how much of the part is broken and or missing, you might find a combination of what you have plus a brass T fitting plus the PC 7 will get it working.
You have nothing to loose.
Posted on Dec 08, 2009
  • 3 Answers
SOURCE: Hunter PGP Sprinkler Problem
For a small price, it's worth it to replace it with another Hunter PGP. Don't settle for cheaper products as the PGP is the best in the industry, bar none.
Posted on Jan 12, 2010
How do I get my Hunter ICC irrigation control box to turn on?
Check batteries with tester. Check internal fuse (sometimes same compartment as batteries. May have have to spend the $20.00
Jan 18, 2015 | Hunter ICM-400 ICC 4 Station Sprinkler...
Hunter pro C will not allow all zones to water.
The fact that you are getting no error message indicates that programming is not right, or there is electrical short between timer and sprinkler solenoid:
With all digital timers, it is important to clear memory before starting, and then double-check there are no conflicts in programming.
Page 22-23 of the manual has quick-check procedure for identifying shorts that would cause problems.
Check outlet with circuit analyzer to check for correct polarity and grounding.
Google search Hunter Pro C manual to download searchable pdf manual
Keep in mind also that digital timers are susceptible to line noise, and power surge. Simple power outage can disable digital timer. There are no replacement parts.
That's why I recommend good old fashion 14-day repeat-cycle mechanical sprinkler timer with fewer features, but replaceable parts.
For example T8845PV with 24Volt ac output
Jul 15, 2012 | Hardware & Accessories
My digits are dimming or fading making the watch hard to read. Battery reading is "high"
mcdevito75 Here, The battery could be loose makeing a weak connection or the LCD screen could be going bad, Have a small watch repair shop in your area check it out. If you can do so yourself be very carefull as too much pressure on the battery (PRESSING) could destroy the LCD face of the watch, also if the display (FACE) of your Casio ever goes black, even if display returns, the LCD is going bad.
Feb 05, 2011 | Casio G-Shock GW700A-1V Wrist Watch
I have a Orbit 57161 Sprinkler System 6-Station Standard Indoor Mounted Control Timer with rainbird sprinklers the issue that I have is the sprinklers stay on and don;t turn off.what do i do?
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Oct 04, 2010 | Orbit Sprinkler System Power Source...
Hunter XG sprinkler timer not working
REPLACE the alkaline battery can be used to program the controller in the absence of AC power. Even without a 9-volt battery the EC will keep track of time for up to 1 month and retain the program indefinitely in the event of a power outage.
Oct 06, 2017 | Hunter Ceiling Fan Control Switch
My Hunter PGM sprinkler heads are stuck in the same position. Any way to fix this?
Hunter has released the PGJ sprinkler, a direct replacement of the PGM series. With a rubber cover and the smaller PGP type gear drive, the PGJ series rotor should solve your issue. I would look at and find a wholesaler near you for costs of replacing your PGM sprinklers.
Jul 18, 2009 | Ace Hardware Hunter& Low Profile III...
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Hunter sprinklers vs rainbow sprinklers
I work with both Hunter and Rainbird irrigation components. Both companies have good products. But, I prefer Hunter for the sprinkler heads and Rainbird for the controllers and valves.
Oct 30, 2008 | Ace Hardware Hunter& Low Profile III...
Jul 09, 2008 | Ace Hardware Hunter& Low Profile III...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
