Am trying to enable blutooth on a samsung series 6 tv. It is not bluetooth. I have a transmitter and a digital to analog convertor. I have connected the optical audio out to the convertor.
Then the convertor to the transmitter but not sure using right connection.
skotkolr
  • 558 Answers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Posted on Apr 27, 2008
SOURCE: Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Posted on Dec 11, 2008
i just hooked up my sony blue-ray to my samsung suround sound.but i cannot get the sound to work.
Posted on Dec 14, 2008
srinivasb81
  • 51 Answers
SOURCE: right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Posted on Jan 08, 2009
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Posted on Sep 24, 2009
How to connect to a Samsung tv
If you have Samsung wireless and need to pair them, then select sound, addition setting arrow down to Bluetooth ( may not be visible until you arrow down). Follow those instructions.
below this you will find how I set up old headphones.
I have a Samsung SU 4K, I also have an old wireless head phones. I did not want to buy expensive Bluetooth.
how did I make these work. First I purchased a digital optical convertor for $20. Since my headphones are 2 channel, I connected the base (red/white) to the convertor. Then I had to access Samsung menu audio. The Samsung TV has the manual built into TV terrible. Since I did not want the TV speakers off I had to find how to enable the output to headphones base. Select sound from menu , then additional settings , set audio format to PCM, also HDMI to PCM.
Jan 10, 2016 | Samsung Radio Communications
Bluetooth connection
I've never seen a TV with built in Bluetooth. Some sound bars can connect to your phone with Bluetooth and others use Bluetooth to enable the accompanying subwoofer to operate wirelessly so you can place it anywhere. Most sound bars connect with an optical cable to audio out or digital out on the back of the TV.
Nov 27, 2015 | Samsung Televison & Video
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
Wireless headphone connection on Samsung UN40H6203AF
Are the headphones regular wireless (with a transmitter, sometimes called base or dock) or are they Bluetooth headphones ?
Jan 01, 2015 | Audio Players & Recorders
Can beats s450 be connected to any soundbar?
If the soundbar is Bluetooth-enabled, yes. But I have not read or heard about a Bluetooth-enabled soundbar yet. And why would you want to connect the headphones to the soundbar ? The only situation where this would make any sense is if the soundbar were hooked up to a TV. If this is the case, your only solution is to use regular (not Bluetooth) wireless headphones, which consists of two pieces: the headphones and a transmitter that you hook up to the audio output of your TV. The transmitter piece transmits any sound coming out from your TV wirelessly to the headphones.
Sep 27, 2014 | Beats By Dr Dre - Wireless Bluetooth...
Connected Auvio Bluetooth speaker to Samsung LN-S3241D TV via digital optical wire and digital-to-analog audio adapter; the sound plays great but the volume can not be adjusted with the speaker controls,...
Check your menu on the Samsung to switch audio out selector. You might have to use ANALOG outputs instead.
you could then eliminate digital to analog adapter.
Analog out uses the RCA PLUGS.
Jan 10, 2018 | AUVIO Bluetooth Portable Speaker
Bluetooth conection
I had to download the blutooth stack to my laptop. You might also need a usb blutooth transmitter. About $10.
Jan 01, 2009 | Toshiba Satellite A205-S5812 Notebook
Do I have an analog or digital TV ?
You have an ANALOG set. After 2/17/09, you will need to be connected to cable, satellite or get a convertor box to watch this set.
Mar 24, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
