Question about Gateway Computers & Internet
Went into hibernation, now no power!
I have taken all components out of the laptop except the cpu heatsink and 1 RAM, and did not get anything on the diaply again once I powered up. I did notice that the thermal grease was hard and dried up on the heat sink and processor, removed the old grease, and applied new grease. Nothing came on at first, so I popped in the System Restore disc, and it finally came on after days of not working, however that did not last long, it hibernated, and now it will not power on again. Same ol' thing, power l ight comes on, cd rom spins, CPU fan is on, nothing on diaply or any other lights. What could have gone wrong? Bad motherboard maybe?
  • Luke Stewart Jul 21, 2009
    Thanks Tim,
    I had tried swapping out the RAM and it made no difference, I had tried all components to see if I can find what was wrong by trial and elimination, but I get the same results. I think it has been having some heat issues for a while, it was running extremely hot, the stickers underneath were curling from the excess heat, so maybe it's the motherboard, overheated, it was working for all of 20 mins, and once it went into hibernation that was it. I think this one may just be scrap, this would be the second time the motherboard would be replaced.
    It was helpful...
    President:
  • 2,777 Answers
That definitely sounds like a bad motherboard to me. I would try swapping the stick of ram with the other one (if you have another one) and see if that makes any difference. It's normal for thermal grease to dry up after a long while like that, it's possible that it had some heat issues and the processor finally gave out. It's definitely one of the three things you mentioned there, in order of likeliness I'd say motherboard, CPU, then RAM.
Let me know what you think, without parts that you know work to swap in and verify it's almost impossible to know which is the culprit.
Tim
Posted on Jul 21, 2009
Cpu fan works, power supply fan works why wont' computer come on?
Could be a number of reasons:
The CPu fan and the PSU fans will come on, even though the system is not working. There is a possibility that the CPU has blown, you can check this easily by (carefully) feeling the heatsink after it has been running a while. A dead CPU will not use power and therefore not heat up. If after say 10 minutes of running, the heatsink is clay cold, suspect the CPU. Replace with another one, spreading CPU grease on the top before putting the heatsink back on.
A blown CPU will usually be indicated bu there being NO beeps from the system (see below)
If the CPU appears to be generating heat, visually inspect the board, look for blown or blowing capacitors (the small cylinder like components) on the motherboard, any that are bulging or leaking a brown residue, or have blown, will render the motherboard inoperative.
If these appear ok (they still may be damaged), unplug all components except the hard drive, and ram and video card, see if the system then boots. If it does, proceed to re-installation of each in turn, until the faulty peripheral halts the boot.
Listen for any beeps as the ssytem switches on these beeps describe the type of problem
(repost if you hear any beeps)
Remove one stick of ram and try rebooting, if it works, suspect the ram module, try the other and see if that makes any difference.
Failing that, your last recourse is to power the system off, remove the bios battery, replace after 2 minutes and see if clearing the Cmos "unsticks" the computer.
After That, suspect the motherboard is dead.
Apr 25, 2011 | Computers & Internet
Doesn't load the anything beeps continually at about 1 second intervals
The beeping is the mainboard giving you a fault code!! Remove everything that you have plugged into the board except the cpu and its heatsink. Now, boot the machine, If it still beeps, check the cpu is seated correctly or return the board. If it now boots (it will still beep because no RAM is installed) then shut it down and refit each item one at a time, booting it after each item is fitted. When it stops booting again, the last item you refitted is the cause, replace it. If it boots when everything is refitted, you had a hinkey connection, Pay carefull attention to RAM sticks and expansion cards ( graphics cards, internal modems) etc. This is a common issue and removing and refitting the various components will usually cure it. TAKE NOTE that ALL computer components do not like static discharge. You may have already damaged the board or components and not know it. Make sure you discharge yourself by touching the metal chassis of the case BEFORE you touch anything else..
Jan 06, 2010 | ASUS P4S533-MX Motherboard
Navigate to a web page watch video - laptop switches off after 3 mins - stays on for hours otherwise
Sounds like the laptop is going into hibernation. Have a look at power management to check on what hibernation is set to.If you are watching streaming video then the cpu etc are not doing anything, only your graphics chip is working and as the graphics chip is not polled by the power management system, it thinks you have left the laptop and hibernates it !! Increase the delay for hibernation or turn hibernation off. Just remember to close the screen when you leave the system unattended as this will also initiate hibernation..
Dec 26, 2009 | Computers & Internet
CPU NOT DETECTING ERROR CODE FF
If you are having trouble booting the system and getting a screen try the following multi-step procedure. Power off your system first before completing any of the following tips.
1) Check CMOS clear jumper JP1 (JBAT1 on some systems). Set for CLEAR for 5 seconds, then move back.
2) Check CPU host clock jumpers (if any) are properly set. Note: does not control memory bus.
3) Check your power supply. Should be 110/115v for North America.
4) Unplug all data cables for IDE and FDD from the motherboard.
5) Unplug all power supply cables attaching to your IDE and FDD drives.
6) Remove all cards and devices EXCEPT for video, RAM, CPU, CPU heatsink/FAN.
7) Move memory into a different bank, if available.
8)Unplug the CPU and reattach.
9) Ensure your CPU heatsink/FAN is attached properly to the CPU.
10) If you use a variable RPM fan ensure its set for full speed.
11) Retest.
12) If 1-11 do not help power off and test the motherboard outside the computer case to eliminate a case/motherboard power short.
13) Retest. If the board now works check for case problems. If the system still is not working continue…
14) You may have a possible hardware problem. Any device in the system may be a possible culprit. Use process of elimination to determine the cause. Swap out as many components as possible starting with RAM, CPU, POWER SUPPLY, VIDEO CARD (if present) and/or MOTHERBOARD.
Jul 30, 2009 | Mercury P4VM800M7 Motherboard
Hp laptop random shutdown - overheat?
Your CPU is likely overheating. Very likely the thermal conducting material between the CPU chip and the heatsink may have shrunk and now impeades the thermal transfer.
You may need to remove the heatsink and put new thermal paste and perhaps copper shim to restore the thermal contact to the heatsink.
Jan 04, 2009 | Everex StepNote XT5000T Notebook
Laptop hibernates randomly
go to the control panel and open power option change your setting there
Oct 04, 2008 | Computers & Internet
Hi, i have a advent 7011 laptop that runs really slow. it has a 2.4Ghz processor, 256mb ram 30Gb HD (20.5gb free). i did a fresh XP Home install a few months back but it is still very slow - once an item...
Most slow portable systems (Once software has been eliminated as a cause) run slowly do to problems with cooling the processor. Possible solutions include:
1. Cleaning out the heatsink fins using canned compressed air by repeated blowing in the intake and exhaust vents.
2. Replacement of a failed or failing CPU cooling fan and/or heatsink (Normally I replace both, as some heatsinks use vacuum tubes and the tubes can lose their seal and become ineffective)
3. RARE: Replacement of the processor
4. Just in case you havent checked these SW/Firmware options. In the BIOS make sure the CPU is running in a NORMAL mode (Some have a compatible mode which slows the processor dramatically) Also ensure the power management settings in Windows are set to Maximum Performance/ALWAYS ON
Jun 15, 2008 | Computers & Internet
Upgrade
to upgrade your going to have to take the laptop apart and remove the heatsink on top of the cpu, then disconnect the cpu, and then install another cpu in place of it, apply therman greeze and put the cpu heatsink back on. and reassemble your laptop.
Mar 31, 2008 | Computers & Internet
Continuous Beeping, new PC
Hi.
Continues short beeps... means a short OR no power OR loose card OR system board.
Test it without the keyboard and mouse too. Just the Processor with heatsink, motherboard, memory and Video card.
Now add the keyboard, no mouse yet.
Check also the voltage of the CMOS Battery it should be 3V.
keep me posted for the result... count also the beeps.
Feb 09, 2008 | Intel Motherboard
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
