Question about Exercise & Fitness
I'm sorry. Maybe I should give more detail? I have a brand new PRO-FORM spin bike model 2.0 ES. THe display console is very dim. I changed the D cell batteries and it is still very dim. ???
MNfisherman
  • 11896 Answers
SOURCE: Brand New mens Diamondback mountain bike, with
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
Posted on Aug 17, 2009
SOURCE: Model 25865 cordless handsets have hardly readable
mybe der is sum dust on the screan?
Posted on Oct 23, 2009
  • 118 Answers
SOURCE: display not working after battery change
some have a small reset button on the back where you push it with a pencil tip. That may help!
Posted on Oct 28, 2009
SOURCE: It has just stopped showing a picture in either
I gave the camera a jolly good bang!!!
The pictures then appeared.
I hope this will last.
Gerald Slee
Posted on Jan 20, 2010
nedkelly900
  • 345 Answers
SOURCE: bike will not start or stay running on a full
sounds like the problem is your battery is not charging when you are riding. The most common cause is a faulty regulator / rectifier. Contact a motorcycle wreckers for these parts, or your yamaha dealer.
Easy way to test is, when your bike is running, and the lights start to dim, before the bike shuts down, using a volt meter, test the voltage at the battery terminals, should be about 14V. If faulty rectifier,no charge going in to your battery, then the reading will be low, about only a few volts. If you dont have a volt meter, then any mechanic shop can do this test for you. best to have this done before buying any parts.
Posted on Aug 11, 2010
Display console is VERY dim on our brand new 2.0 ES?
2.0 litre ES Vehicle? Turn the dimmer wheel to increase the brightness. Normally between steering wheel and the driver's door.
Or Google
year make model manual
Most are online
Google
Jan 04, 2017 | Video Game Consoles & Games
I have Pro Form 300 CR Bike the console lights up but buttons don't work..
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jul 12, 2016 | Exercise & Fitness
How do I get unit out of demo mode...it is stuck and will not turn off demo mode
Here you go
Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the exercise bike is displayed in a store. If the demo mode is turned on,
the console will not turn off and the display will not
be reset when you finish exercising.
You can turn on or turn off the display demo mode.
From the settings menu, select Demo Mode. The
currently selected demo mode option will be
highlighted.
To turn on the demo mode, select On. To turn off
the demo mode, select Off.
Your manual is here.
http://www.sportsmith.net/images/product_support%5CProForm%5CPFEX013112%20-%20PROFORM%20LE%20TOUR%20DE%20FRANCE%20BIKE%5CPFEX01311.2-320509.pdf
Sep 19, 2015 | Proform Pro-Form Tour De France Spin Bike
Ifit light flashes. Everything works properly except light flashes, which is distracting and irritating.
o 1 Check the connection cablebetween the Pro-Form device and the home stereo, computer, television or VCR ifthe iFit program is not working. Ensure that both the Pro-Form device and thestereo device are both turned on in order to function properly.o 2 Connect the Pro-Form deviceto the computer prior to logging onto the website iFit.com if the iFit programsare not downloading or operating on the computer. The fitness device mustremain plugged into the computer at all times in order to use the iFit programsduring the workout.o 3 Insert the console key andpress the "Program Select" button repeatedly if the iFit program isnot working properly. Ensure that the fitness device is connected to thedesired output device, such as the computer, television, VCR or MP3 player. TheiFit indicator should be lit on the console display.o 4 Press the "Start"button on the console if the time display is flashing on the Pro-Form device console.The iFit program will not function while the time display is flashing.o 5 Listen for a chirping soundif the incline or speed changes suddenly on the fitness device. The chirpingsound indicates that a speed or incline change is about to take place, even ifthe iFit program has not announced the change.
Nov 09, 2011 | Exercise & Fitness
The screen on the laptop has gone extrmely dim and the fn button with the brightness button will not work.
It sounds like your display backlight has gone out. This is usually because the inverter board in the display, which provides power for the lamp, has gone bad. Replacement inverters are available for most brands of laptops, and they aren't hard to change. Search for your specific brand and model and "replacement inverter" and you should find several sources for the part, and sites with details of how to change it.
Jul 17, 2011 | Acer Computers & Internet
Hi, im from Kota Kinabalu and have this acer aspire 4315 with NO display (Dimmed display) . It is working fine when i use an external monitor. Fyi, i have a 2 unit used working fine power inverter and lcd...
unfortunatly there are three pieces involved in the dimming of the screen. 1) the lcd (you tried that) 2) the inverter (you also tried that) and 3) the motherboard. I had the same thing happen with my daughter's acer. I bought her a new computer and sold the laptop for parts.
Motherboard replacement on these are a pain.
Sorry for the bad news ... Good luck
Nov 29, 2010 | Acer Aspire 4315 Notebook
Namashkar Sir, I have pur Zeus 125cc bike of suzuki from Big Wig Motors Nagpur. form the day one there was problem of starting , noice in chain, viberation misfiring etc within 10 days 2 battrys were...
You have had many problems. That is not fair. Was the bike brand new when you purchased it?
All new machines have a manufacturers warrenty.
If your bike was brand new when you bought it call the company who made it and not the company who you bought it from and tell them your problem.
If it is not right (and yours sounds like it is not),you should complain to the manufacturer.
Because your problems are so bad they should really replace it for you.
In Australia where I live you can go to a government department called department of fair tradeing who help solve problems like the one you are having.
Check in your country if you have the same.
I really hope you have some luck as what has happened sounds not fair.
You may be able to complain against company that sold you the bike.
If it is a licenced buisness or the you should be able to complain to the government body that give out the buisness licence.
Or if the mechanic is a licenced trades person, you should complain to the government body that gives out the trades licences.
I feel sorry for you
I hope this helps you
from Andrew Porrelli
Dec 07, 2009 | Suzuki GSX 1400 SE Motorcycles
I have a ti 83 plus calculator and when i type in say radical 50 i want it to give me 5 radical to not the decimal form how do i change this
Your TI83 calculator is a powerful machine but it does not do symbolic algebra. Results are always displayed in decimal form
(Did you notice that it does not have a %key.)
Some new (not very expensive) calculators can do that : Casio FX-300es, Casio FX-115es,Casio FX-991ms or es. These type of calculators are known as NATURAL DISPLAY, or WRITE VIEW (from Sharp).
Hope it helps.
Aug 21, 2009 | Texas Instruments TI-83 Plus Calculator
Scooter won't start when I pull the rope, needs flywheel?
Change the fuel pump in the tank? How about the lift pump? Is the cable attached to the throttle body?
Aug 06, 2009 | Mini Motorized Bike
Exercise & Fitness Logo
27 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
