Question about Dryers
I have replaced A control panel and the wire harness thing on my Cabrio steam dryer . My dryer will run but it still does not heat. Do you have any other suggestions
  • 65 Answers
SOURCE: Cabrio Dryer Front Panel Removal
a putty knife at the corners
Posted on Feb 16, 2008
  • 1122 Answers
SOURCE: Cabrio Electric Dryer Heating Element
have you checked the high temp thermostat?
Posted on Sep 05, 2008
  • 864 Answers
SOURCE: NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
Posted on May 29, 2009
projdoc
  • 2237 Answers
SOURCE: Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
Posted on Jul 24, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
WHAT IS THE F1 ERROR MESSAGE
F1 error code is a miscommunication between the control board and the rest of the machine. Check for any loose or damaged wires. If no loose or damaged wires are found, replace the control board and this should clear up your problem.
Oct 22, 2015 | Whirlpool Cabrio 7.6 Cu. Ft. 11-Cycle...
The control panel of cabrio dryer wed6600 has air bubbles where function area control are. It works fine but looks bad. Should I pull it up and press it down?
None othe these answer actually answer the question, the question is about a cometic issue. To the person who posted this this question have you figured out a way to fix it?
Pleas note that the dryer was running when this pic was taken.
Feb 16, 2015 | Whirlpool WED6600WL Cabrio Steam 7.0 cu....
Cabrio Dryer WED5500XWO not heating up
Is dryer conrtolled by 2 breakers ,if so one is for heat the other for power.
Jan 29, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio wed6200sw0 dryer runs, won't heat up. blows air, lint line is clear and hi limit thermostat and thermal cutoff okay (have continuity) at room temp
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | Whirlpool WED6200S Electric Dryer
Dryer tumbles but does not heat
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things: Mainly the Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element and wiring harness should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Kenmore 93042 Gas Dryer
Dryer won't heat...it is about 5 years old
Hi
Thanks
Rylee
Jun 21, 2010 | Frigidaire FEQ1442ES Electric Dryer
I have a Kenmore (Whirlpool) Elite HE5 Steam front load dryer. Everything seems to work fine except there is absolutely no heat. I checked the breaker, and it wasn't tripped. I checked the lint filter and...
I think I know what the problem is, this actually happened on a dryer I repaired at one point. Low line voltage to me means that one or more hot leads is not feeding enough voltage to the heating elements (and the heating elements need both hot leads to run) which means the circuit breaker, although on, may be malfunctioning or weakening. You can check this by running your dryer and taking the cover off your circuit panel and checking voltage on the breaker. You should see 110V on each terminal to ground (put leads from one terminal to the grounding bar in the panel). If you see less than 110V on each lead to ground and less that 240V across the terminals it needs to be replaced. (You can get one for under $25.00 depending on brand). NOTE: THE BREAKER USUALLY POPS RIGHT OUT OF THE PANEL, BUT WHEN WORKING IN PANEL TURN MAIN BREAKER OFF TO THE HOUSE AND HAVE SOMEONE HOLD A FLASHLIGHT FOR YOU. IF YOU TOUCH THE LIVE BUSS BAR THAT BREAKER GOES INTO YOU WILL GET SEVERELY HURT. TURNING OFF MAIN BREAKER WILL DISENGAGE THE POWER FROM THE BUSS BARS; NOTE THAT MAIN WIRES ARE STILL POWERED SO BE CAREFUL.
Mar 22, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Jul 24, 2009 | Whirlpool Dryers
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
