Question about Video Game Consoles & Games
Display console is VERY dim on our brand new 2.0 ES?
  • Video Game C... Master
  • 19,050 Answers
2.0 litre ES Vehicle? Turn the dimmer wheel to increase the brightness. Normally between steering wheel and the driver's door.
Or Google
year make model manual
Most are online
Google
Posted on Jan 04, 2017
Compass not working on 2006 Mercury Grand Marquis
Electronic Compass The compass display and module are contained in the overhead console and are replaced as an assembly. For additional information, refer to Section 501-12 . The compass display can be turned off and on by pressing the MODE button in the overhead console. The vehicle heading is displayed as one of N, NE, E, SE, S, SW, W, or NW.
Inspection and Verification
NOTE: Press the MODE button to turn on the display.
  1. Verify the customer concern by operating the vehicle along roads of known direction to duplicate the customer concern with the compass.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Compass module
  • Central junction box (CJB) fuse 15 (7.5A)
  • Circuitry
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the fault is not visually evident, determine the symptom and GO to Symptom Chart .
Pinpoint Test A: The Compass Is Inaccurate/Inoperative
Normal Operation The compass receives battery voltage from the central junction box (CJB) through circuit 964 (DB/LG). Ground for the compass is supplied through circuit 676 (PK/OG).
    Possible Causes
  • fuse
  • circuit 676 (PK/OG) open
  • circuit 964 (DB/LG) open or short to ground
  • compass zone setting
  • compass calibration
  • compass module
PINPOINT TEST A: THE COMPASS IS INACCURATE/INOPERATIVE NOTE: Always set the zone and calibrate the compass before replacing an inaccurate compass.
NOTE: After installing a new compass, always set the zone and calibrate.
Test Step Result / Action to Take A1 CHECK THE OVERHEAD COMPASS DISPLAY
  • Key in ON position.
  • Check the overhead display.
  • Does the overhead compass display remain on after prove out?
Yes
GO to A3 .
No
GO to A2 . A2 CHECK THE COMPASS MODE
  • Press and release the SELECT switch on the overhead console.
  • Does the overhead compass display turn on?
Yes
If the compass display turns on correctly, GO to A3 . If the compass display turns on, but the heading is inoperative/inaccurate or the display indicates VAR, GO to A4 . If the compass display turns on, but it does not display all directions, or indicates CAL, GO to A5 .
No
GO to A7 . A3 CHECK THE COMPASS DIMMING
  • Turn the headlamp switch to the parking lamps ON position.
  • Does the compass display dim?
Yes
TURN the headlamp switch to the OFF position. GO to A4 .
No
TURN the headlamp switch to the OFF position. GO to A8 . A4 CHECK THE COMPASS ZONE SETTING
  • Set the compass to the correct zone for your location. Refer to Compass Zone Adjustment in this section.
  • Does the zone adjustment set correctly?
Yes
GO to A5 .
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A5 CALIBRATE THE COMPASS
  • Calibrate the compass. Refer to Compass Calibration in this section.
  • Is the compass calibrated correctly?
Yes
GO to A6 .
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A6 CHECK THE COMPASS ACCURACY
  • Position the vehicle at each of the 8 directions (N, NE, E, SE, S, SW, W, NW) and verify that the displayed heading is accurate. The vehicle must be stationary for at least 10 seconds at each direction.
  • Is the compass display accurate in each direction?
Yes
The compass is OK. REVIEW the operation of the compass with the customer.
No
INSTALL a new overhead console. REFER to Section 501-12 . TEST the system for normal operation. A7 CHECK THE VOLTAGE SUPPLY TO THE OVERHEAD CONSOLE
  • Key in OFF position.
  • Disconnect: Overhead Console C930.
  • Measure the voltage between the overhead console C930-1, circuit 964 (DB/LG), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
TURN the key to the OFF position. GO to A9 .
No
VERIFY the CJB fuse 15 (7.5A) is OK. If OK, REPAIR the circuit. TEST the system for normal operation. A8 CHECK THE DIMMING CIRCUIT
  • Measure the voltage between the overhead console C930-4, circuit 484 (OG/BK), harness side and ground while rotating the instrument panel dimmer switch.
  • Does the voltage vary between 0 and 10 volts?
Yes
GO to A9 .
No
REFER to Section 413-00 for further diagnosis of the instrument cluster and panel illumination. A9 CHECK CIRCUIT 676 (PK/OG) FOR OPEN
  • Measure the resistance between the overhead console C930-2, circuit 676 (PK/OG), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
No
Nov 30, 2017 | Mercury Grand Marquis Cars & Trucks
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Hola me gustaria recuperarlo mi nueva cuenta de gmail se que es rochoaI al ultimo terminal con 2 pero no me recuerda cual es e tend muchos y este no me a Cuervo me ayudan
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 02, 2015 | Televison & Video
Toyota prius problems
Check the battery connections are firm, not loose, grab and wiggle them. They should not move.
Dec 21, 2013 | Cars & Trucks
Dim display
If you have the 12C Platinum, turn the calculator on. Press and hold the f key, then press the + key to increase the contrast.
Mar 09, 2013 | Office Equipment & Supplies
Bought brand new car audio head unit CQ-RX420W. 2 questions if anyone can help please. 1. The aerial wont retract when a non radio source is selected. 2. There's no orange wire in the loom for dimming the...
The antenna generally will not retract until the power is turned off at the deck or if you turn the key off (which turns the deck off).Your deck may have a selectable dimmer function in the settings menu you should be able to set it to automatic and it will handle the dimming on its own then.
Jan 30, 2010 | Panasonic Car Audio & Video
The display is dim on the oven. Everything works
1. Sometimes you can clean it inside to brighten it up for a while.
2. In some cases, we can replace the VFD to brighten one up if it's available for a given model.
3. The last solution is to replace the control circuit board.
For more specifics on the options 2 & 3, we would need your brand and full model number.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well as your symptoms, "dim display".
As for suggestion # 1, cleaning:
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Dec 13, 2009 | Jenn-Air JMC7000 Microwave Oven
Use vb.net and access
Imports System
Imports System.IO
Imports System.Data
Public Class SaveImage
Shared Sub main()
Dim o As System.IO.FileStream
Dim r As StreamReader
Dim gifFile As String
Console.Write("Enter a Valid .Gif file path")
gifFile = Console.ReadLine
If Dir(gifFile) = "" Then
Console.Write("Invalid File Path")
Exit Sub
End If
o = New FileStream(gifFile, FileMode.Open, FileAccess.Read, FileShare.Read)
r = New StreamReader(o)
Try
Dim FileByteArray(o.Length - 1) As Byte
o.Read(FileByteArray, 0, o.Length)
Dim Con As New _ System.Data.OleDb.OleDbConnection("Provider=Microsoft.Jet.OLEDB.3.51;Persist Security Info=False;Data
Source=Test.mdb")
Dim Sql As String = "INSERT INTO images (Pic,FileSize) VALUES (?,?)"
Dim Cmd As New System.Data.OleDb.OleDbCommand(Sql, Con)
Cmd.Parameters.Add("@Pic", System.Data.OleDb.OleDbType.Binary, o.Length).Value = FileByteArray
Cmd.Parameters.Add("@FileSize", System.Data.OleDb.OleDbType.VarChar, 100).Value = o.Length
Con.Open()
Cmd.ExecuteNonQuery()
Con.Close()
Catch ex As Exception
Console.Write(ex.ToString)
End Try
End Sub
End Class
Jul 08, 2008 | Microsoft Computers & Internet
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Video Game Consoles & Games Logo
52 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
