Question about Garden
Chain came off .Went to put back on and when u tighten the screw closest to chain the chain moves as should but if u tighten the back cover screw the chain sticks and won't move as should
    Top Expert:
  • Garden Master
  • 49,126 Answers
Did you loosen the chain brake ?
Posted on Jan 04, 2017
  • Chastity Keele
    Chastity Keele Jan 04, 2017
    Not sure what u mean I released the handle yes but never had a saw with a break so that's all I knew to do.The chain moves good till u tighten the back bolt closest to the saw handle .once u titen it ,it seems to sick and won't move but so far and hangs up
  • ray gallant Jan 05, 2017
    the front handle is the brake and if it is in the wrong position the chain will not roll as it should . keeps some of us safer is it's purpose .
SOURCE: Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Posted on Oct 03, 2008
  • 6 Answers
SOURCE: Chain falling off on small load
New bar and chain should do the trick. ONCE IT GETS A LITTLE DULL T BUILDS UP HEAT AND STRETCHES. Use a good quality case hardened chain they last longer and are well worth the extra money.
Posted on Jan 04, 2009
  • 152 Answers
SOURCE: Poulan chain saw. After starting, chain drive won't move
If equipped, the chain brake may be engaged. Its the lever just ahead of the fore handle. (pull back on it)
If the clutch assy. were frozen, then the chain would move all the time.
Good luck
Posted on Mar 11, 2009
  • 597 Answers
SOURCE: fix the tension tightener for ryobi chainsaw
the nut like end of the tention bolt should fit into a hole in the bar. Then as you unscrew the bolt later one it ill push the bar farther away from the bolt heal thus tightening the chain
Posted on Jun 03, 2009
  • 2220 Answers
SOURCE: How do I tighten the chain on my Remington 14 in.
Mitch if you attempted what is in the manual, and it is not working we would have to see and touch the saw to determine what has failed. If you loosened the bar bolts before trying the adjuster and it did not work, I suggest a trip to a local saw shop.
Chain adjustment pages 1, 8 and 9.
This is from a Remington OM
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Posted on Apr 03, 2010
How do I put the chain back on the electric chainsaw
Remove the cover over the sprocket. There should be a screw that has a pin on it that fits into a hole in the bar. Turn the screw to move the pin towards the rear of the saw. You have moved the pin far enough when you can slip the chain onto the bar. Place the cover back on the saw and tighten the cover so the bar can still wiggle up and down. Turn the screw the screw to move the bar forward till the slack is removed. Put on some gloves and you should be able to move the chain around the bar. If you can not the chain is too tight.
Feb 22, 2015 | Electric Garden
How to replace ryobi electric chain
There should be a tensioning screw that needs to be backed off to allow the bar to be moved towards the back of the saw. I am not sure on your saw if the screw is on the cover or on the saw side of the bar. So start by taking off the cover over the bar then you will see the tension adjusing screw. On the screw will be a peg that fits into a hole in the bar. Turn the screw so the peg moves towards the sprocket. When the bar is far enough back you can place the chain over the bar and sprocket. Then with the peg in the bar put the cover back on and turn the screw to move the bar forward till the chain is snug. If it is too tight the chain will not move around the bar. With gloves on you should be able to move the chain around the bar. If you can not it is too tight. Back off the adjusting screw till you can then fully tighten the cover screws.
Nov 26, 2013 | Garden
Sumo chainsaw
First take off the cover over the sprocket. You should see a peg that goes into a hole on the bar. Find and turn the adjusting screw to move the bar towards the sproket till you can put the chain on. Now put the cover back on just snug. Now turn the screw to push the bar away from the sprocket. To test put on some gloves so you dont cut your hands and see if you can move the chain around the bar. If you can and it is not drooping you are close to proper tension. I pull up on the chain and if you can see the whole drive link it is too loose.Snug it just a bit more so the bottom of the drive link is just in the groove. Tighten up the cover screws and your done.
Sep 07, 2013 | Garden
Chain fell off and I can't get it back on.
Turn the saw off. Look for several nuts on the right side of the saw that hold the cover on and the blade to the saw. Loosen these nuts, and before taking the cover off, loosen the chain adjuster by turning it (usually a screw head on the same side, or on the front of the saw as you look down the blade towards the saw.) Loosening the chain adjuster moves a pin that goes into the bar (the part the chain rides around when operating) to push it away from the saw to tighten the chain when you are tightening it. Take the cover off, and put the chain around the sprocket at the back like a bicycle chain, and then while holding the bar (sometimes a partner helps) parallel to the saw and outward away from the front of the saw, align the bottom parts of the chain inside the bar guide slot all around the bar, holding just enough tension that it doesn't fall off the sprocket or get misaligned in the bar guide. Try moving the chain a little bit to make sure it is not binding on anything. If it doesn't move at all, make sure the chain brake is not on. Once it is moving smoothly, put the cover back on, and begin to hand tighten the nuts. Just before they begin to get tight, eyeball where the chain tensioner pin is in relation to the hole it is supposed to go in. Adjust the chain tensioner screw to move the pin towards the hole. When it pops in the hole, continue tightening the nuts by hand until tight. Now you and your partner can let go of the bar. Adjust the chain tensioner for the proper tension in the chain, not too loose, not to tight, refere to your manual. Finish tightening the cover nuts using the universal wrench to the specifications given in the owners manual.
Sep 06, 2011 | Poulan 14" Electric Chainsaw
New Rancher 455. Ran for a few minutes then tried to tighten chain but adjuster was maxed out (completely tight clockwise). Removed cover, now can't get tension adjusting pin in hole in sits...
Ok.. with the cover off the clutch you notice the screw and the pin that is suppose to go into the hole.. with the chain on the bar back the screw until the pin sits in the hole of the bar.. The chain should be lose you will see the chain dangle at the bottom of the bar.. put the cover back on with it lose.. hand tighten the two nuts that hold the cover on. with the bar in hand and you pulling the bar up make sure the two nuts are on tight enough so the bar does not move but dont over tighten it. tighten the screw you will notice the chain starting to move, and start to tighten up.. once the chain is in the grove of the bar grab the chain and move the chain with your hand to make sure you have not over tighten it. if the chain moves freely and is not lose ( you can also double check how tight it is by grabbing the chain below the bar and letting it go if it snaps back into the bar and doesnt hang there you are where you need to be.) tighten the two nuts up on the cover and start up the saw. Run the saw to make sure everything is all set and nothing is lose before cutting.. If the chain never get to tighten up you need a new chain. buy a new chain and follow the steps again. let me know if you have any questions
Jun 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
There's two 1/2 inch nuts on the side of the cover from which the bar protrudes.
Remove these nuts and the cover -- leave the bar loosely in place.
Look for a slot-head chain-tensioning screw (may be on front under the bar, or perhaps on the side).
Turn this tensioning screw counter clockwise -- you will notice a pin moving back towards the drive clutch -- this pin fits into a hole on the bar and is used to set the chain tension by pushing the bar away from the drive clutch.
Once it is loosened, the bar can be pulled closer to the drive clutch, allowing you to fit the chain back onto the bar -- be careful to align the drive teeth on the chain into the slots on the drive clutch.
When the chain is back in place, turn the tensioning screw clockwise to tighten the chain onto the bar.
Replace the cover and put the nuts back on only finger-tight.
Tighten the chain some more using the tensioning screw.
Tighten the 1/2 inch nuts fully.
Note: The chain needs to be quite tight -- lift it by a link and be sure it does not come out all the way from the bar.
Nov 13, 2010 | Husqvarna Garden
Cannot move the chain by hand after the bar has been tightened.
First be sure the chain is on going in the right direction. When looking at the bottom of the bar the sharp tooth should be going towards the motor. When you put chain back on are the chain teeth properly engaged in the sprocket on the motor. Remove the cover again, check that teeth are in sprocket. Make sure pin from adjuster screw is engaged in the hole in the bar. Before you tighten the cover bolts, make sure chain will turn by hand. If not adjust the adjusting screw. Once adjusted, tighten cover bolts. Check again after tightening bar.
Jul 04, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Had plug in saw 2 weeks and it dose not work /// it spins but dose not move blade just loud clicking noise
ok i assume it is an electric chain saw? chain usually gets loose and can jump off clutch sprocket . to remedy this there should be atleast one nut or bolt sometimes two nuts or bolts depending on brand and model on the side cover where bar and chain inter the clutch area remove those and cover will lift off second there is a screw that faces front next to bar should be a regular slotted screw head loosenit all the way up till bar gets loose and remove bar by pulling away from saw this will come off veryeasy and chain shoouls fit on teeth of clutch sprocket and fit back onto bar tighten screw till chain tightens up on bar then replace cover and nuts on side cover but do not tighten the with one hand put tension on chain by pulling down on it while tightening screw till chain feels elastic snapping back to bar then toghten up nuts . chain should have no more then 1/4 inch slack around bar this is the correct tension youshould maintain.
Mar 18, 2010 | Poulan Garden
Chain came off ,need to know how to put it back on!!!
On the chain saw there should be a panel held on by two screws or nuts where the bar and chain is attached. Remove the two screws or nuts and the panel and you will expose the chain and sprocket. Loop the chain around the sprocket and bar. Put the bar with the chain around the sprocket back on the saw, reinstall the cover with the two screws/nuts, but do not tighten too tight.(You will want to be able to move the bar with the chain.) Then pull the bar away from the saw to tighten the chain, once the chain it tight, then you will retighten the screws or nuts to lock the bar and chain in place. Be sure you lube the chain and bar with "Bar Oil" before starting to put the saw into service. Good Luck...I hope this helped Please rate me, Thanks
Jan 04, 2010 | Water Heaters
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
