Question about Samsung LE40R74BDX 40 in. LCD Television
Samsung LE40R51B no picture but turns on
Hello experts,
my Samsung 40'' LCD TV turns on and swiches channels, plays sound, but does not show any picture. You can see the background light. But its black all the time. What can be the problem? some electronic in the LCD or could be the LCD panel faulty?
regards
Simon
  • clean_cut_05 Apr 07, 2008
    I have a samsung 40" lcd to and it turns on for about 9 sec then the screen goes blank. The tv stays on but no picture, then if i turn it off and back on again it works again for another 9 seconds. What do you think this is?
    New Friend:
Tcon is dead replace it
Tcon module # 400w2c4ltv0.1
Posted on Nov 24, 2013
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
Try to replace CAPACITORS with value 1000uf 25 volts, replace them with 1000uf and 35 volts, the power supply overcharges the capacitors due to powerpeaks of 29.7volts, the priginal capacitors cant handle those peaks,.. in the menu turn off options dynamic contrast and digital noise filter and all is fine again! it worked on my samsung.
Yours sincerely,
Dennis
Posted on Apr 04, 2013
  • dndmusic
    dndmusic Apr 04, 2013
    try to replace CAPACITORS with value 1000uf 25 volts, replace them with 1000uf and 35 volts, the power supply overcharges the capacitors due to powerpeaks of 29.7volts, the priginal capacitors cant handle those peaks,.. in the menu turn off options dynamic contrast and digital noise filter and all is fine again! it worked on my samsung.
    Yours sincerely,
    Dennis
I have the same problem i was told by a repairman that samsungs are known for bad psu. and that its expensive to repair
Posted on Feb 05, 2008
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Sound but no picture or anything on the screen.
Ur LCD inverter backlight board is dead.Replaced this LCD inverter baclight board will get ur picture back.Tries Websites Shopjimmy.com,Ebay.com to buy a LCD inverter backlight board for the replacement.It a long board in shape.
Mar 23, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
My samsung 40 inch lcd tv is not swiching on it just keeps making a clicking noise
HELLO, I AM ALMOST SURE THAT YOU HAVE BAD CAPACITORS ON THE POWER SUPPLY BOARD, IF YOU OPEN THE SET LOOK FOR THE SWOLLEN CAPS THAT IS A COMMON PROBLEM WITH THIS SAMSUNG LCD TVS
GOOD LUCK
CAYPIANAN@YAHOO.COM
May 10, 2009 | Sanyo DP42746 42 in. Plasma Television
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Sony Bravia 46S2010 no picture only glows but, only sound on
sound like you had problem with the lcd display panel. The Tcon had problem that attack to the panel.
Mar 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound
Hi,I have samsung T.V. but nearly 2 OR 3 months we had a problem of no sound (It is an on and off trouble) .can you tell me about this?
Name-Om Prakash Pareek
Address-H-32 shastri nagar,jodhpur
phone -2641100
Jul 21, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung lcd tv no picture just sound
While this is not a permanent solution, we've fond it helps... We have a Samsung LCD that does not turn on when there is too much humidity in the room. This only happens in the summer when it gets really humid. We moved our dehumidifier next to it, let it run for around 15 minutes and the TV turned on again, no problem. Lately, it's been raining alot so it's very humid. We've gotten into the habit of leaving our dehumidifier on through the night on low and we've had not issues turning on the tv since then. This is a hastle but it's either that or buying a new tv.
May 26, 2008 | Televison & Video
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Oct 24, 2007 | Televison & Video
Samsung LE40R74BDX 40 in. LCD Television Logo
980 people viewed this question
Jerry Greenberg
Jerry Greenberg
