Question about Garden
Where can i get a snow blower for a 06 38" simplicity 16hp?
4 Suggested Answers
mikkibtune
SOURCE: simplicity snowblower stopped augerin. how do i change shear pin?
Make sure the motor is off and the key is out. Look on the center of each side of the axle that contains the blades. Rotate the blades slowly until you find the holes left by the missing bolts. stick a small screwdriverin the back of the hole to keep the keyway aligned. PLace the new bolt on the end of the screwdriver ( that should be facing you ). Slowly push the bolt through the keyway until the screwdriver pops out the other end. then attach the nut and tighten firly but do not overtighten.
Posted on Jan 06, 2010
flyfisher94033
  • 10 Answers
SOURCE: light bulb keeps blowing out on simplicity snow blower
Same thing happens to mine... voltage is spiking and blowing the bulb,also hand warmers get too hot. needs a new voltage regulator. I'm trying to get simplicity to replace under warranty since I brought it into an authorized repair place for this before the warranty was up.
Posted on Mar 06, 2015
jimflower89712
  • 861 Answers
SOURCE: simplicity 16hp kohler runs fine shut it off will just crank has spark and fuel? Interlock module?
give it a shot of carb cleaner in the carb. if it fires you have a fuel problem. if not change to a different spark plug see if that starts it. if not check compression. and valves
Posted on Sep 27, 2016
Light bulb keeps blowing out on simplicity snow blower
Jan 29, 2015 | Simplicity L1528E 2-Stage Snowblower...
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
May 13, 2014 | Rotary Snow Blower Parts Replaces Ariens...
Why does the shearpin in the driveshaft break on a simplicity p1728e snowblower all the time
You're either working it too hard (heavy hard-packed snow) or picking up rocks. Better that you break a shear pin than that you damage a shaft or the engine! Shear pins are CHEAP compared to engines.
Feb 27, 2014 | Simplicity I924E 2-Stage Snowblower...
Remove impeller
they are all pretty much the same , look on youtube
Jan 08, 2014 | Simplicity P1524E 24" 305cc Signature Pro...
Present holder of dealer franchise will not service sno blower because it was not purchased from themi
Any Dealer of Simplicity should Service any Simplicity machine.
Find the Simplicity manufacturer website and e-mail them.
That present holder my find he wont be able to sell Simplicity anymore
Jan 04, 2014 | Simplicity Garden
The drive quit working on simplicity snowblower
the drive as far as to make it go forward and reverse?
may be adjustment or the belt is bad or the drive wheel is worn too far to adjust to make drive
Dec 16, 2013 | Simplicity I924E 2-Stage Snowblower...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
