Question about Sewing Machines
I have a 99-13 Singer. I wound bobbin and pushed down the bobbin winder pulley. Bobbin wound thread and automatically released balance wheel. Problem appears stop motion screw. Won't sew.
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
SOURCE: Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Posted on Jun 26, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 1116 Answers
SOURCE: thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Posted on Mar 13, 2010
Bobbin winder not working
none I have ever had CATCH the thread . you have to thread to the bobbin and hold the end till it gets a good start .
Feb 12, 2016 | Sewing Machines
When winding the bobbin thread slipped off tension disk and wound around the bobbin shaft. When I removed the thread the bobbin will not fill with thread.
Well, you COULD get this fixed -- or you could purchase an inexpensive bobbin winder and skip the whole issue. Does a better job, too.
Oct 30, 2015 | Singer 7258 Sewing Machine
If you mean the Singer Style Mate 347, open the face plate and remove the old bobbin. Then, the first step is to hold the hand wheel and loosen the stop-motion screw inside the hand wheel. (Keep the hand wheel from turning with one hand and turn the stop-motion screw towards the front of the machine.) Place your empty bobbin (hole away from the machine) on the spindle near the bobbin winder switch. Feed the thread from the spool on the spool pin through the eyelet on the top of the machine (near the top thread take up) and then down to and around the bobbin tension disc below the on-off power switch. Pass the thread through from the inside of the bobbin to the outside of the bobbin. Move the bobbin winder switch to On and hold onto the end of the thread. Start the machine and let a few winds get placed on the bobbin then stop for a minute. Cut the thread near the bobbin. Restart and continue winding more thread onto the bobbin until you have enough thread or the bobbin is full (it will stop automatically). Move the bobbin winder switch to off and tighten the stop-motion screw.
For pictures, see pages 6-7 in the manual. It's available as a PDF here: . (These are pages 8-9 of the PDF.)
I hope this helps.
Jun 06, 2013 | Sewing Machines
Bobbin won't wind on Singer futura CE-100
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
Sep 09, 2012 | Singer CE-100 Futura Computerized Sewing...
I have an old Singer, Model #6146 from the late 70's or early 80's, can't remember when my mom bought it, but I can't remember how to thread it and I don't know how to put the thread on the bobbin. Any...
Cotton reel on top, take the thread from the reel to the left and over the top guide, straight down throught the tension discs, back up to the take up lever making sure the lever is at the top, through the lever right to left, straight down through any guides and thread needle front to back.
To wind the bobbin, reel of cotton on top, bobbin on bobbin winder making sure it is pushed to the left, take the thread to the left and round the small wheel and back to the winder, wind the thread round a few times on the bobbin, push the windewr to the right, and loosen the stop motion in the balance wheel.
Mar 27, 2011 | Singer 2250 Tradition
Bobbin stuck on bobbin winder. wont release
If, it is a plastic bobbin and you mean the bobbin thread is too tight and the bobbin will not move, take a art razor blade and start cutting the thread to release it. Sometimes, the plastic grabs the spindle when it is wound too tight, you may have to take pliers and break the bobbin to get it off.
Jan 30, 2011 | Singer 7422
How do i add thread to the bobbin? i have wound it and placed on the knob, and pulled out the wheel but nothing is happening..
when you place the bobbin on the bobbin winder on top of your machine, you then push the lever closest to it into the bobbin until it clicks. most newer machines will automatically quit using the needle when you are winding a bobbin if its an older machine there may be a push button on the wheel or you may have to loosen the knob inside the wheel to keep the needle from operating , you then use the foot pedal to wind just as you would to sew. Bobbin will automatically pop when full, be sure to redo anything that you had to undo to wind bobbin.
Oct 28, 2010 | Kenmore 15516 Mechanical Sewing Machine
Make sure that you have it wound around the thread guide the correct way, or else you have no tension, and that your bobbin pushed against the bobbin winder. Study your manual, and if you need one with bigger print go to and download one for free, then adjust your text size. Good luck
Oct 02, 2010 | Singer Sewing Machines
Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Jun 27, 2009 | Brother CS-8072 Computerized Sewing...
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
