Question about Dehumidifiers
I need room temp butter and mine is frozen. How can I thaw, but not melt the butter?
    Master:
  • 469 Answers
Cut off the amount of butter that you want( cutting corners off is best) and allow those sections to stand on the bench What Function Does Mouse Pad Carry Out AmanStino
Posted on Jan 04, 2017
    Top Expert:
  • Dehumidifiers Master
  • 51,171 Answers
to get those sections to thaw quicker , cut them into smaller pieces as the less mass to stay cold the quicker it thaws out
Does not generate water. The fan keeps on running. Forms ice on coils
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 06, 2010 | Danby DDR586R Dehumidifier
Have Whirlpool AD50USS - unit ran for over 24 hours in DRY mode but collected no water. Should have been water in bucket as basement smells musty.
Dec 28, 2009 | Whirlpool Dehumidifiers
When do you use the dehumidifier?
In areas with poor circulation and humidity over 80%.
Dec 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Unit comes on compresor and fan run but not collect much water
Dec 28, 2009 | Kenmore 54501 Dehumidifier
Fan is running but the air coming out is not hot. How to fix the problem
Dec 26, 2009 | Sunbeam Dehumidifiers
My 320 is powered up and running but is not collecting any moisture
low outside temp means low indoor humidity
Dec 22, 2009 | Amcor MD250 Dehumidifier
My challenge dehumidifier runs ok but does not collect any water , whats the problem?
low outside temp means low inside humidity
Dec 20, 2009 | DeLonghi Dehumidifiers
My ad25usv whirlpool dehumidifier is full of water but wont drain into the bucket?
Dec 10, 2009 | Whirlpool AD25BBK Dehumidifier
White westinghouse dehumidifier freezing up
hopefully its not the coolant pump seizing. the only simple thing that goes wrong with those is the water full switch, which turns off every thing. try playing with the float thing in the tank, you shoud here clicking of the switch on and off
Jun 15, 2009 | Whirlpool AD70USS Dehumidifier
Iced up coils and will not dehumidify
I did a little digging around on the internet and found out that if the basement (or where ever you have your unit) is in an area where the room temp might dip below 65 degrees the coils may start to become "too efficient" in pulling the moisture/humidity out of the air and it begins to freeze on the coils before it can drip off into the reservoir. The site said to turn off the unit and let it thaw out, then restart it and see if everything works ok after that. If the temperature gets too low you might need to warm up the air in the room/basement before it will operate correctly again/not continue to freeze up. Hope this helps. Mine just did the same thing but we've had some pretty cold weather recently and the basement is fairly cold as well.
Jan 20, 2008 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifiers Logo
178 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
