Question about Kitchen Ranges
I replaced a lm3-24 after 10 years with the same model after 2 days the housing of the cell has turned brown where the coil is towards the rear I rang zodiac to be told this normal
SOURCE: Kenmore Model #790 - smooth top range
Probably not. It sounds like your broil element burned out. This just happens sometimes. If it is this , it will have visible chunks missing. Yes, It shorted with enough force to blow the main fuse. Unplug it as sometimes it can still be live and sparking when power is restored. Element is fairly cheap usually less than $50 and you can fix it yourself.
Posted on Jun 29, 2008
  • 2920 Answers
SOURCE: REPLACEMENT COST OF MAGIC CHEF ELECTRIC RANGE MODEL 6898XVB
you should be able to buy one for between 400 to 600 dollars new.i would check lowes or home depot to see what they have in stock.
Posted on Jan 13, 2009
  • 336 Answers
SOURCE: Picture issue
Hi,it sounds like the LCD chips that create the image and colors.These chips are green,blue and red.These chips are like tiny screens that blend together to create the image and colors.Over time the LCD chips start to melt and those spots will appear.Unfortunately they dont sell the chips by themselves so you will need to replace the light engine which cost sometimes as much as a new tv.Good luck and God bless you!
Posted on Nov 03, 2009
vetteman3002
  • 2299 Answers
SOURCE: i have a whirlpool super
If the voltage at the plug is still only 125 volts on the black and 16 volts on the red. There is still a problem with the power. And has nothing to do with the stove. You should have 240 volts when you measure from red to black. You can check the power at the breaker to make sure that you have 240 volts on the new breaker. If you have the right voltage there, then you either have a bad connection in the range plug or a broken wire somewhere between the breaker panel and the plug in.
Posted on Nov 05, 2010
KevinWhite
  • 1902 Answers
SOURCE: Whirlpool range GJP84202 My food was
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Apr 11, 2011
Mx360 cdi circuit
Hi, Anonymous all this electronic brain surgery is above my pay grade Good luck and have a wonderful day.
Jun 24, 2017 | Yamaha Motorcycles
WHIRLPOOL DRYER Model Number LER7646EQ1 WILL NOT RUN
take the 9 hex head screws out of rear cover remove cover then on the blower housing toward the left side where the black duct comes down from the lint chute theres a thermal fuse on this round shaped housing with 2 wires to it its about 1" long by 1/4" wide if this opens the unit will appear dead,you can test it or bypass it for testing only if bad it needs replacing as its there for fire safety,also if its open/bad clean out any lint as this lint will cause overheating and burn out this fuse
May 21, 2012 | Whirlpool Dryers
Where to locate nissan 1993 300zx speed sensor
On all 300zx NA the speed sensor is on the passenger side of the transmission. There is portion called the adapter plate in the middle of the transmission when looking at the side profile. This plate is about an inch thick and seems to separate the transmission from the front main body to the rear housing. The speed sensor is just aft of this (towards the rear of the car). It is round smooth top with a set of wires coming out of it leading up to a brown plug (no sure if color changed for different years)
Oct 26, 2011 | 1991 Nissan 300ZX
Vornado fan Model CR1-0023 , Type 750 I bought this fan used 3 days ago. Seemed to work fine but not as powerfully as another new Vornado shop fan I have. Today the fan blades stopped turning. I can...
I have had the same model for almost ten years, and have had to lubricate it twice - both times when the fan stopped rotating. It's obvious that Vornado never intended the bearings to be serviced, but if you're patient, it can be done. You must remove the front louver section (press the three clips inward gently). Then firmly pull the fan toward the front, off the shaft. Then remove the four nuts on the front of the motor housing - you'll note that the bolts appear to be free-floating, but that allows re-assembly after the bearings are lubricated. When the nuts are removed, firmly pull the front of the motor housing toward you. This may require a firm pull or GENTLE prying, as the rear bearing sometimes doesn't want to let go. When you have the front portion of the housing and shaft out, hold the housing and pull the shaft out of the front bearing. Again, this may require a steady firm pull straight back. When the rotor & shaft are free, you'll need some very fine emery paper to remove the varnish that's built up on the shaft (it's unmistakable where to clean the shaft.) And I never attempt to do anything with the front and rear bearing themselves - too much work, and cleaning the shaft does the job for me. Then clean everything up carefully and lubricate the shaft where it enters the bearings (and maybe a drop in the rear bearing itself.) I use a very fine machine oil that I bought at Sears, but I think any good oil would work. Then, it's re-assembly time - shaft into front bearing, shaft into rear bearing as the motor housing is put back together (lining up the bolts), four nuts on the bolts & tighten (firmly, no gorilla), press fan back on shaft (don't force it too far on - it'll stop when it's in the right place), plug in and check, re-attach front louver (just press - the clips will snap easily into place.)
Jul 27, 2011 | Vornado CR10023-06 Air Circulator Fan
Have kitchenaid undercounter ice maker, came with the house i bought a year ago. the problem is the water freezes in the resevoir. i have replaced the circulating pump, the thermistor, some sensor,...
on the right side of the ice bin and above the cutter grid are 2 sensor plugs, unplug the one towards the rear of the machine (usually has light brown w/red striped wires). if this does not fix the problem then replace the main control board and the transformer. Also the water doesn't go to the grid, it rolls across the evaporator, freezes a slab of ice that then slides down to the cutter grid. the cutter grid should be somewhat warm, it is what cuts the ice into the little squares. I've worked on these machines for around 7 years now and have only seen this problem once, this should fixya
Mar 02, 2011 | KitchenAid KUIS18NNT 18" Automatic Ice...
Hi our Sony wega keeps switching itself on and off sometimes it gies a day without doing it and then sometimes it does it every 5-10 minutes model number is KLV-L32M1??? any ideas?
Try this temporarily-
Position a portable fan toward the rear of the unit aiming it at slots in the rear housing.
If this causes the set to stay on longer, you probably have some cheap capacitors in the main power supply that are failing and will need to be replaced.
Nov 24, 2010 | Televison & Video
Ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Ryobi Garden
How do i set the carburetor on a Stihl FS-55 weedeater.
Over the past 8 years, the FS55 has had at least 5 different carburetors, and they have at least 3 different systems with different adjustments. Many of them do not have much of an adjustment and will not cure running problems. If you are experiencing poor running conditions, I would suggest some basic checks first. The spark arrestor screen is a big culprit on this model.
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 23, 2009 | Garden
Brown staining of clothes,increased noise on spin cycle
that brown sludge is grease from the bearings and the noise is the bearings breaking up stop using the machine and get them replaced 2 supply and fit new bearings and drum support should nt cost more than £90 good luck not realy a job 4 a novice
Aug 06, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
