What size screws for tv base on model 65HT2U?
97F350diesel
  • 1326 Answers
SOURCE: I have a 37 inch olevia hd tv..It was mounted on
This is a difficult one as you have about 50sizes possible for this one. Try calling olevia and giving them the model # they might have that info but its pretty technical and more then likely you'll need to go to a Home depot and just pick up several fine threaded screws (about $.05-$.10each) and try em all to see which one fits. Its a pain but may be the only way. Make sure you don't get them too long as this will damage the threads or not tighten the mount. Try about 1" to 1-1/2" screws. depending on how thick the base plate is. you want about 3/4" of the screw inside the tv depending on how deep the threads (can stick a toothpick inside it to gauge how deep) so ad 3/4" to the thickness of the base plate.
Posted on Sep 13, 2009
  • 148 Answers
SOURCE: need screw specs to attach base assy to tv
I
Hi there, if you are trying to just remove the base, then on your model there is one screw in the center of the underside of the base. If you want to remove the neck of the base to then remove the 8 screws on the back of the tvs neck too. I hoped this helped, please rate thank you!
Posted on Feb 05, 2010
SOURCE: need to know what size screws go in to the tv base
I ended up having to take my entire tv into Home Depot. This is what the package says on the screws that worked:
"Machine Screw Pan-Slotted 4mm- & X 20mm Stainless Steel BR-B/ 12-B/322"
I know this is an old post but since I couldn't find any answers when I was looking I wanted to help someone else out.
Posted on Apr 01, 2010
  • 87 Answers
SOURCE: I lost the screws for the base mount for a vizio
Local ACE Hardware, take one for sample
Posted on May 13, 2010
SD Tech
  • 14553 Answers
SOURCE: i have a 60 inch LG Plasma tv and the base stand need screws need to know what size screws
See a lot of this kind of problem: easiest way is with the model number call the LG customer service number and get the bolt info for number and thread type---IN ALMOST EVERY CASE THE BOLTS WILL BE STANDARD FINE THREAD AND AVAILABLE AT MOST PLACES LIKE HOME DEPOT.
Posted on Apr 16, 2012
What size screws attach the swivel base to the Dynex LCD-TV Model DX LDVD19 10-A? There are screw holes. Many thanks!!!
take it to a repair shop and have them check the hole size they may actually have screws just for that reason
Nov 05, 2017 | Dynex Televison & Video
How to find replacement parts for my television base
For 22" or 19" Emerson TV base 3 screws (M4 x 12)
Emerson LC190EM2 User Manual Supplied Accessories Symbols Used In This...
this size may differ for your TV based on its size and quantity may differ based on the design / model of your TV.
could have helped if you mentioned the model number as well.
May 26, 2016 | Emerson Televison & Video
What size screws to use for the issue described below?
Sometimes the base screws, on brand new tvs, come in the 4 holes in back for mounting the tv on the wall.
Dec 08, 2015 | Toshiba 40FT1U LCD TV
What size of screws/bolts do I need to mount the base to the TV?
It uses metric machine screws. You may have to spend some time at your local "big box" store searching for the right hardware, BUT length is important from a safety perspective. Insert a toothpick in one of the holes and mark where it is flush at the top. Take your toothpick to the store and match length with the M4, M6, etc. screws you will be sorting through.
A large screen TV such as yours requires two people to place it screen down on a soft surface such as a blanket for hardware installation. Be sure to tighten the screws firmly. Enlist the same two people (or designated alternates) to lift the TV and place it where it should be located.
Sep 05, 2015 | Westinghouse Televison & Video
I have lost the screws to my 50" soniq tv base. What size screws do I need
Buy an inexpensive screw hole size template (used for inserting screws of unknown size into it, and reading what size hole it fits into, and then going to buy that screw) at Home Depot (HD) or Loews. If there is room to lay the template over one of the holes, you can eyeball which hole on the template is about the same diameter of the screw hole on the base. Then go to the store and look for that size screw (machine screw Vs wood screw), and purchase one of each of three sizes (the one that appears to be the one, and one that is the next size down, and one that is one size larger. Then see which one fits in the base (this will be a bit of trial an error). This should work until the right size is identified.
Sep 19, 2014 | Televison & Video
Size of screws for sanyo 55 inch LCD to mount base to tv
After repeated trips to the hardware store and more calls to Sanyo and conversations with supervisors...depending on the year of the TV....2011 requires M5x16. The next year model requires the same size that bolt to the back of the TV. I had to elevate my request for the size of the base screw of the 2011 model all the way to engineering before I got the answer. They changed the configuration in the 2012 and later models.
Jan 02, 2014 | Sanyo Dp55441 TV
Vizio E470VL - What is screw size for mounting stand?
I don't know if the screws would be different depending on the tv model, but on a Vizio Model E470VLE 47" LCD HDTV, the screws for the base are M4 x 30ST.
May 21, 2012 | Vizio Televison & Video
Missing screws for detachable stand for vizio e370 va
Try to contact (says your set is Vizio here) the company who made it...Also try to GOOGLE MODEL NUMBER OF SET WITH "MOUNTING BOLTS"
Mar 24, 2012 | Vizio E370VA 37 1080p 60Hz LCD HDTV
I LOST THE SCREWS OF MY TABLE TOP STAND OF MY TOSHIBA TV MODEL: 47HL167, AND I WILL LIKE KNOW WHAT THE SIZE OF THE SCREWS. IS FOR THE BACK BOTTON OF TV
Read the informations of those screws to tighten the tv and the base stand together.Read it in ur owner manual for those exactly screws sizes.Standard screws tvs sizes for a 46" are screw (M4 X L16).
Feb 14, 2011 | Toshiba REGZA 47HL167 TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
