Question about Samsung Dryers
When I turn on my Samsung dryer the display panel is stuck. The power will come on but you cannot adjust any of the settings. It says de on the front but none of the buttons appear to be stuck.
alvinbga
  • 130 Answers
SOURCE: front panel buttons won't work and auto adjust in progress keeps flashing
Main board problem or a connector is not fully inserted
Posted on Jul 02, 2008
  • 59 Answers
SOURCE: SGI F180 Flat Panel Display no longer turns on.
If the power button does not stay on, the monitor might be burned out.
Posted on Aug 20, 2009
Testimonial: "Your answer is what I thought might be wrong. Is there anything that can be replaced?"
  • 732 Answers
SOURCE: i have compaq tft8020, from last 2 days i m facing
mr farhanpk, When very strange stuff starts to appear on the screen of any older model ccfl -back-lit lcd display I would certainly suspect and investigate the monitors ac to dc internal power supply for BAD, SWOLLEN, LEAKY electrolytic filter capacitors. Check your pc with a "known-good" monitor to make certain it is not the pc causing the problem. 12fixlouie
Posted on Aug 11, 2010
budmrtn
  • 11361 Answers
SOURCE: Samsung Syncmaster 245BW displays no image. Unit
Send me the pictures of the board (both sides) then I may be able to tell you the test points on the board, budmrtn@aol.com
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 24, 2010
technical114
  • 1851 Answers
SOURCE: I have an ASUS MW221u
In most of the cases like yours the problem is at the buttons at the lower of the screen. In case one of these buttons is pushed and locked in, all the buttons are blocked. First of all check that the buttons are mechanical working; push them one by one in order to feel the click of the button. In case of one (or more) are not clicking they have problem and has to be replaced. There is the possibility that the click is active although the button is defective; this is because the inner contact of the button is dirty or damaged. In this case you have to open the monitor's case (usually you have to remove the screws at the back of the monitor and open the cover slowly in order the clips all around the frame to get unlocked), spray with a contact cleaner direct at the buttons and push each one several times to get cleaned. By the way that the cover is open check the cables connecting the buttons board with the rest for possible cut or loose contact. VERY carefully plug the monitor and check the results. In case that the problem is still active one of the buttons is defective and needs replacement using soldering tools.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Nov 12, 2010
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
I can not select a cycle on my belling idw450. Power is on
the program button on panel could be stuck or moisture in it. If there is no error displayed on panel, then take a hair dryer and on warm setting run it along the switch panel.
if error message is displayed then try to address the error first.
The program switch sits on top of the panel module which looks like this http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=1933696&query=Belling%20IDW450%20panel&model=IDW450&path=67231,297877:297772
It is the small board in front middle of the assembly.
Apr 20, 2014 | Dishwashers
Tv turn on and oof by self
Try unplugging the tv at the wall outlet or from power bar, for a count of ten then plug back in, should reset tv.
Hope this was helpful
Apr 19, 2014 | Samsung P2770FH 27 LCD Monitor 1 ms 1609...
How to adjust my laptop brighteness
You didn't post your OS? In win7 or vista, open Control Panel, select Power Options, select High Performance, select Change plan settings, adjust Display. If you are using battery power the Laptop will do a auto dim to conserve battery power. If this doesn't help post the Samsung Model and the OS you are using for a precise solution.
Apr 30, 2013 | Samsung Computers & Internet
Can i get the service mode of samsung TV?
# Turn on the TV on and select the input that you want to adjust.
# Turn the display off.
# In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}
Feb 15, 2012 | Televison & Video
I have a new Samsung side-by-side refrigerator (model # RS265TDRS) that I am using for the first time. I plugged it in today, and the control panel display has been flashing "23 E" all day (NO...
Push and hold power freeze and power cool simultaneously until display flashes. Release and leave alone. You just reset the brain on your display. In an hour or so, reset the desired freezer and refrigerator temps. My suggestion, -6 on freezer, 44 on refrigerator.
May 16, 2017 | Samsung RS265LBBP Side by Side...
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
I have a Samsung DV316BWG/XAA Gas dryer I have power at the outlet, the digital display is working when I set the time and push the start button I get nothing. No error codes and I get 2 blinking bars on...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 25, 2011 | Samsung Dryers
The moniter light will blink on and off randomly and the screen also turns on and off with the light. What can I do to fix this?
This is most likely due to power management settings for the monitor.
To address these settings follow the procedure below for your version of Windows.
To establish which version of Windows you have:
Press and hold the Windows Logo Key on your Keyboard + Press Pause Break Key and release.
To adjust power management settings in XP:
Click Start > Control Panel > Power Options > Adjust the drop-down menu for your Monitor.
To adjust power management settings for Vista:
Click Start > Control Panel > Classic View > Power Options > Click "Change Plan Settings under your current plan (the plan with a filled bullet) > Click "Advanced Settings" > Click Display > Click "Turn off display after"
Select 0 for none or choose the duration of inactivity to wait before Windows blanks your screen.
Apr 30, 2009 | Samsung SyncMaster 205BW LCD Monitor
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
