I HAVE AN ARISTON AQXXD 149 H AUS WASHING MACHINE THAT NEEDS NEW BOWL BEARINGS, CAN THEY BE REPLACED OR IS IT A NEW BOWL JOB? IF THEY CAN BE REPLACED, AND IF THERE ARE ANY SPECIAL TOOLS REQUIRED.
    Top Expert:
  • Washing Mach... Master
  • 50,592 Answers
Bearings can be replaced but if the machine is more than 10 years old, any aluminium parts will be corroded from washing detergent
the bearings will be available from a bearing retailer but the seals may be difficult to source for the age
best discuss the problem with a technician as it is not a straight forward job and the cost for the fix may be close to a new machine
have the problem properly diagnosed first and then make a decision
Posted on Jan 04, 2017
How to change ball bearing washer machine
Washing machine main bearings are not a picnic to replace and often needs a major stripdown for access.
If the washer is otherwise in good condition and a premium brand it is an economic repair for the repair shop to carry out. Great savings can be made by changing the bearing yourself but do not begin the job unless you are certain you are competent, have a good range of tools to hand and prepared to spend more once the job has begun. As well as the bearing kit you will need a new tub seal and possibly a new spider.
It is generally reckoned not to be economic to have the bearings replaced at the repair shop if the machine is a basic or budget model. In this case it is definitely a diy project.
Oct 06, 2015 | Washing Machines
Ariston AQXXD 149H. Won't empty. How do I correct code F 05?
It is possible that pet hair has passed through the filter and clogged the pump.
Aug 05, 2015 | Washing Machines
Hotpoint wmf560 aquarius washing machine
BIG JOB !!! The whole machine has to be stripped down. Ie/ The complete bowl assy has to be removed from the machine, the outer bowl separated from the inner bowl, the main seal removed, and the bearings pressed or knocked out of the housing in the rear of the outer tub. If the bearings have failed , it would be almost certain that the drum shaft has worn and or been damaged. You will need a set of bearings, drum spider shaft assy, and main seal. If its an older machine, it may not be worth it.
Apr 13, 2015 | Washing Machines
My machine starts to fill leaks out of bottom not from hose then turns off and locks. AQXXD 149 H
if not leaking from hose? then either pump or tub itself is leaking? did u check the tube line from water pressure switch?
Mar 17, 2015 | Washing Machines
Machine will not finish cycle and water remains in washing machine
if the washing machine does not drain, continues to fill or fill too slowly the issue could be the pressure switch. if you have a multimeter use it to find any electrical issues if there is no reading the pressure switch needs to be replaced
Jan 29, 2011 | Ariston Technologies Ariston AWD12 Front...
Noisy Washing machine drum
To replace bearings is quite a job. iyf your good at diy i rate this as a 9/10 ....A bearing kit is available from makers and instructions.
Apr 03, 2010 | Ariston Technologies AWD120WH Ariston
Hi, My name is Atanas, I am trying to change bearings on our Ariston avd149. I just found out it is not possible to get out the inner drum. How do I support the inner drum with the axis when putting the...
I needed mostly advice on how to put back in place the shaft of the inner drum in the bearings without using a hammer... Now I found solution on this- just use a screw bolt. Hope this works…
Thanks
Nov 16, 2009 | Ariston Technologies AW 149 NA
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
