Question about Car Audio & Video
I need a diagram for a xdvd700 - Car Audio & Video
Where can I find the service manual for the Dual XDVD700 Car receiver?
the first pdf should do the job...just download it
www?. dualav.com/.../manuals/xdvd700.pdf...
Nov 17, 2015 | Dual Car Audio & Video
XDVD700 Car DVD Player: I'M TRYING TO FIND BYPASS CODE?...
You do not need a bypass code. Pull out the stereo unit, take the parking brake wire and disconnect it from the parking brake sensor ground. Reconnect it to the radios ground wire and this will tell it that the vehicle is always in park and your videos will work while driving. It must be the stereos ground not just grounded to the frame or something. Must be a live source ground wire.
May 18, 2010 | Dual Electronics XDVD700 Car DVD Player
How to test the xdvd700 before I install in the car. what wires go to possitive and what to negative
Hello there,
Well the wiring colors appear to be standard for most every piece of mobile A/V equipment out there.
Yellow = Battery Power(12V Positive)
Black = Ground / Battery Negative
Red = Vehicle On / 12V+ (or also hook it to the 12V Positive for "always on")
Here's the manual with the wiring diagram on Page 6(page 7 of the PDF):
http://www.dualav.com/support/manuals/xdvd700.pdf
I hope that helps
Mar 31, 2010 | Dual Electronics XDVD700 Car DVD Player
I locked my dual xdvd700
well i just figured out this solution. if you have made three attempts and locked up your XDVD700 stereo, all you have to do is unplug your battery for 5 or more minutes to reset the lock. then you will see the uncreen keypad asking for password again. :D
Feb 18, 2010 | Dual Electronics XDVD700 Car DVD Player
I need the master unlock code for the dual xdvd700
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Sep 04, 2009 | Dual Electronics XDVD700 Car DVD Player
Any luck on that dual xdvd-700 code?
what is the code for the dual xdvd700
Mar 26, 2008 | Car Audio & Video
Need help on hooking up a xdvd700 dual without ebrake
i have the xdvd700 dual. my screen goes blank when it comes all the way up. is there a solution for that? or is that manufacture's problem?
Jan 30, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
