Question about Food Processors
I have a food processor attachment for my Kitchensid mixer and I can't get the lid to lock
  • 3 Answers
SOURCE: Food processor died
The plastic "clutch" with the teeth is probably cracked or stripped. you can buy a replacement.
Posted on Feb 24, 2008
SOURCE: food processor attachment won't fit the machine
I actually got tired of trying to figure it out and just unscrewed the bottom and removed the plastic part. It works fine now!
I had a screwdriver to use with a mobile phone, I think its called t9 or something.
Posted on Mar 23, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: The Blender attachment will not turn, just grinds and smokes.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
Posted on Mar 17, 2009
SOURCE: need a replacement part for food processor
The motor is runing, but the blade is not turning.
Posted on Mar 18, 2009
SOURCE: lid of food processor
Something I saw on Chowhound worked for me--turn the lid in the back-on direction, then twist it off!
Posted on Apr 10, 2010
Lid stuck on work bowl of kitchen aid processor
This tip is used to remove a stuck bowl from the base of a Kitchen Aid tilt-head mixer. It might work for your situation. Fill the bowl with very hot water (use the food shoot as a pour spout). Now use either frozen gel packs, or a bag of ice cubes, and lay the ice on top of the lid. Wait for a few minutes. The hot water with make bowl expand, ice will make lid shrink, thus loosening the tight lid. I'm assuming that the lid edge fits inside of the bowl, like most food processors do. Try to gently move the lid, and see if it'll give.
Mar 20, 2017 | Food Processors
How do you unlock the lid on the food processor?
The locking happens at the handle. You need to turn the lid counter clockwise to take it off and clockwise to lock it into position.
Jun 01, 2014 | Krups XL6 Power Combi Food Processor
Cannot turn the lid on to kitchenaid food processor
It sounds like you need a new working bowl. It is not uncommon for that safety switch mechanism to fail inside the handle.
Jan 29, 2013 | KitchenAid KFP500 Ultra Power Food...
I can't figure out how to use it.. I just want to make a smoothie!
You can get a manual at WWW. euro-pro.com.
In order to use the blender the food processor bowl and lid must be LOCKED in place. Turn the lid on processor until it's locked. Then you are ready to use the blender. Select desired speed or pulse.
In order to use the processor, remove the blender and place the gray lid in its place. It should be locked. The lid keeps the blender shaft from spinning and allows the shaft on the processor to turn.
To remove the processor bowl, gently lift up on the lid to unlock it and then turn it away from processor. Bowl lifts off. That's it! Enjoy!
Hope I have been of some help to you.
Feb 10, 2011 | Bravetti Platinum Pro Quad-Blade Food...
I got a new bosch mixer, food processor for christmas. The food processor will not go down on the main body of the mixer, because of a white piece of plastic inside the bottom of the processor. I thought...
Not too many people offer to pay for advice, but that's no problem. This is a vollenteer site.
The issue with your food processor is because the cutting chamber and lid need to be correctly assembled so that the tabs on the pot and lid line up andslip into a slot in the handle. This will move the plastic peice out of the way.
A safety device to prevent putting fingers into the pot while in operation..
Watch this video and it will explain it.. about 2 mins in..
http://www.youtube.com/watch?v=EB8fEgTzuXk
Dec 27, 2010 | Bosch Universal Plus Kitchen Machine Food...
Im not sure how to use the attachments for my moulinex masterchef vitasum food processor and how to use them when your making a cake.
Visit this link and fill in the details:
https://www.2instructions.com/search.php?cmarque=MOULINEX&modele=MASTER%20CHEF%20VITASUN
Basically it should be as simple as putting a disc or if making a cake with most food processors, using the universal steel blade attachment by dropping it into the jug and turning to lock. Some machines only need the blade tool to just be dropped in. Then put the ingredients in, fit the top lid until it locks, put the feeder tube in to minimise leaks/spills and then turn on.
Apr 24, 2009 | Moulinex Food Processors
NEED ATTACHMENTS & INSTRUCTIONS FOR GENERAL SLICING MIXER
you got something? I need the manual instruction too, very thanks, for some answer,
bernie238@msn.com
Mar 14, 2009 | General G100L PROcessor Food Processor
I need an explanation as to how to attach the shredder disc to my
Make sure the work bowl handle faces the front of the processor, the feed tube on the lid faces the back of the food processor, and the pusher sleeve lock faces the front of the food processor. Should then connect to the motor trigger.
Dec 19, 2008 | Cuisinart Food Processors
Food processor
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food Processors Logo
74 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
