Question about The Watches
I have a watch that split the belt and I want to know how to get the replacement is the model IZS 7
Split/lap vs lap/split display
Try Googling (timex)(250)(manual) without parens for information.
Oct 10, 2017 | Timex Ironman Watches
How do you get the time from military to normal? and how do yo set the date and time?
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
Sep 19, 2010 | Watches
How do I get my WR 100 ft model # AW60724W off army time.
Aug 31, 2010 | Watches
Trying to convert to military time
Best regards. Jewel
Aug 30, 2010 | Watches
How to change from military time back to regular time on a digital indigo watch with 4 adjustment buttons?
Thank you for contacting FixYa.<br /> <ol id="ecxintelliTxt"> <li id="ecxjsArticleStep1"> Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.<br /></li> <li id="ecxjsArticleStep2"> Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.<br /></li> <li id="ecxjsArticleStep3"> Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.<br /></li> <li id="ecxjsArticleStep4"> Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.<br /></li> <li id="ecxjsArticleStep5"> Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.<br /></li></ol> Contact TIMEX for further assistance at:<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads
Aug 25, 2010 | Timex 1440 Nylon watch
I have a Nexxtech Watch that is both digital and hand driven. I have somehow switched the regular time to a 24 hour clock and don't know how to switch it back. The manual says nothing about it. Any help...
These basic instructions are for most digital watches (and these are for regular to military but you can just follow same instructions to get to oposite) Hope this helps!
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 21, 2010 | Watches
How do you change the time setting to 24 hours?
  • Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  • Step 2 Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  • Step 3 Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  • Step 4 Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  • Step 5 Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
  • Aug 17, 2010 | Columbia All Sport Digi Watch l
    How do you adjust the length of a wrist watch band ?
    This particular model has cotter pins. Locate the head of the cotter pin by looking at the side of the band. On one side the pins will look split like screws. On the other side they will be solid. The side that is split is the side that needs to come out first so you want to use a thin punch and press out from the solid side. make sure you replace the pins the same way they came out.
    Many Times watches also have a micro adjustment on the clasp.
    Sep 18, 2009 | Timex 27191 Wristwatch
    Battery replacement prg 40 model 2271
    The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
    Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
    Watches Logo
    13 people viewed this question
    Top The Watches Experts
    D. E. Hev
    John mullen
    vince
    Are you a The Watch Expert? Answer questions, earn points and help others
