I have a awa tele . model mhdv3209-f4. recently i went to tune it in it asked me for a pin number which it has never done before .is it possible to get a pin no or is there a way to bypass it
    Top Expert:
  • Televison & ... Master
  • 47,830 Answers
Some times pin numbers are asked for but an enter command will move it on
try that
Posted on Jan 04, 2017
Tuning AWA television with no remote?
Universal remotes don't do all the functions that a manufacturer remote do not
http://www.tvremotes.com.au for remotes in Australia
If you use a set top box tuner the TV will become the monitor and the box will become the tuner and use one of the rear or side video inputs and bypass the internal tuner and just programme the stb remote to set the TV volume to the desired level
The above link may have the remote you want but as I am in the UK the server blocks me
Sep 01, 2015 | Televison & Video
My awa digital tv has suddenly lost all tv channels and wont tune them back in i know its not the aerial as i have tested it with another tv the awa has no problems with the playing dvds so its not the...
It sounds like you have lost tuning,you will need either the tuner or Main PCB. It's possible you don't have tuning voltages from the power supply, but most likely your problem is with the MAIN PCB.
Mar 05, 2015 | Televison & Video
I have lines,multy coloured running down r/h side of sreen.about 5mm wide.after a while the tv gets funny screen e.g black and funny colour fading in and out. awa mod mhdv3209-f4 32inch
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Feb 16, 2015 | Televison & Video
Code for awa model MSDV3203-F4
For which remote exactly? Each manufacturer of programmable/learning remotes has their own code base and unique numbers for each code.
Asking for a code is like asking for the postcode/zip code of Acacia Avenue but without specifying the city and district.
Sep 10, 2014 | Televison & Video
PASS WORD PROBLEM
It is possibly a setting somewhere set when you did the re-tune, causing all of the channels tuned to be protected. try looking through your TV's settings for something that might help. Otherwise, we could really use a brand/model # to help you out any more.
Feb 15, 2014 | Toshiba Televison & Video
I turned my tv on and went to tune it in and it came up asking for a pin code. It has never done this before, can you help?
You should try going to the dealer you bought it from. But, try 0000. Factory default. hope it works.
Apr 07, 2011 | Televison & Video
My Sidekick LX is asking for a "Special Code"
once it says to enter your "special code" you hit cancel and it enables the sim pin. then you go to change sim pin, put in your old sim pin and put in a new one. then go to network settings and select "scan and select manually". once you find at&t click done and you can use the sidekick.
Apr 09, 2009 | T-Mobile Sidekick II
Laptop to samsung tele
  1. Ensure that the connection is a direct cable connection from the PC to the TV, no converters or cable adapters as these are generally not Bi-directional which is required for a PC to see a TV.
  2. Try turning on the TV, then booting the computer. Some devices require the initialization signal from the computer to activate the port on the TV.
  3. See if the TV input select has an option to search for active signals.
IF none of that helps, post the exact model of TV and computer as well as the type of cable connection you are using.
The biggest stopper most of the time is a cable converter.
Jul 08, 2008 | Televison & Video
How to tune AWA-Thorn C6337 television
There should be two dials, one is UHF, you need the main dial on U for the UHF channel tuner to work, turn the UHF dial with the main dial on U and if you have a UHF antenna, you should see something if you get a UHF broadcast where you are, the main dial will probably be numbered 0 1 2 3 4 5 6 6a 7 8 9 or something like that, they are VHF channels, should be preset at the factory, but if not, turn the centre of the main dial, you may have to push it in and turn.
In saying all that, i dont know the model, but im pretty damn sure it was the same or simular 63cm AWA Deep Image Colour set that i had from way back in the VERY early 80s. I cant remember that model number though.
Apr 20, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
