Question about Food Processors
I can't get the lid to lock on my food processor
ukvacfan
  • 328 Answers
SOURCE: Broken food processor lid
Check EBAY UK for any older models = you might not be able to get the lid on its own - Moulinex parts are difficult to come by unless they are still being made. Failing that visit UK shops such as Cash Converters or similar - you can sometimes find these food processors there.
Posted on Jan 02, 2009
clyde2j2
  • 137 Answers
SOURCE: I need a new 6 cup holder and lid for my GE food processor.
Try these URLs
www.abtecparts.com---www.marbeck.com---www.smallappliance.com---www.nelsonappliance.com
Posted on Mar 02, 2009
SOURCE: need a replacement part for food processor
The motor is runing, but the blade is not turning.
Posted on Mar 18, 2009
co7196
  • 3433 Answers
SOURCE: need bowl and lid for 5100
Go to this site. or type magicmix in the search bar at the top of the screen, Good Luck
http://www.magimix-spares.co.uk/Parts-for-Magimix-5100-lid,-...
Posted on Oct 31, 2009
SOURCE: lid of food processor
Something I saw on Chowhound worked for me--turn the lid in the back-on direction, then twist it off!
Posted on Apr 10, 2010
How do you unlock the lid on the food processor?
The locking happens at the handle. You need to turn the lid counter clockwise to take it off and clockwise to lock it into position.
Jun 01, 2014 | Krups XL6 Power Combi Food Processor
Tip
The cusinart pro classic food processor is not working ?
Try this procedure:-- It usually goes something like this, with minor variations depending on model number:1.Remove the work bowl completely from the base
2.Plug the food processor in and turn it on
3.Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4.Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the work bowl
5.Place the lid on the work bowl with the tab slightly left of the center of the work bowl handle – slide the lid counterclockwise until it won’t slide any more
6.Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7.Slide the lock to the right into the locked position
The food processor should now work.
This will help.Good luck.
on Mar 08, 2010 | Food Processors
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
Cannot turn the lid on to kitchenaid food processor
It sounds like you need a new working bowl. It is not uncommon for that safety switch mechanism to fail inside the handle.
Jan 29, 2013 | KitchenAid KFP500 Ultra Power Food...
I can't figure out how to use it.. I just want to make a smoothie!
You can get a manual at WWW. euro-pro.com.
In order to use the blender the food processor bowl and lid must be LOCKED in place. Turn the lid on processor until it's locked. Then you are ready to use the blender. Select desired speed or pulse.
In order to use the processor, remove the blender and place the gray lid in its place. It should be locked. The lid keeps the blender shaft from spinning and allows the shaft on the processor to turn.
To remove the processor bowl, gently lift up on the lid to unlock it and then turn it away from processor. Bowl lifts off. That's it! Enjoy!
Hope I have been of some help to you.
Feb 10, 2011 | Bravetti Platinum Pro Quad-Blade Food...
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Cuisinart 7 cup food processor wont' start
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart DLC-5 Food Processor
I have a cusinart pro classic, went to use it yesterday, filled it and turned in on, got nothing. i tried a different plug and still nothing. it is not even making a sound.
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart DLC-10S Pro Classic Food...
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
Food processor
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food Processors Logo
71 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
