Driver side speakers fade in and out. If I turn the volume really loud the speaker will operate but only stays on for a few minutes. Need to repeat the process if I want this side to stay on.
  • 883 Answers
SOURCE: Speakers fade in and out when listening to music
ensure all connectors are properly inserted, then if you have a speaker mounted volume control, then run it back and forth rapidly about 100 times with power off. this will allow the tiny copper "wipers" contacts to brush off any accumulated dust.
Posted on May 25, 2007
SOURCE: Sony CMT CP1 Right hand speaker output very noisy, humming, crackling
It sounds to me like you both are having a problem with a capacitor going bad. some capacitors act as a noise filter and it sounds like you both have a bad one. If you are any good with a volt-ohm meter that reads capacitors you should check them to make sure they are at their proper values which will be posted on the capacitor. then replace it. if you dont know how to use a v-o meter then take it to a shop and have them replace it
Posted on Jan 23, 2008
jerryg50
  • 1689 Answers
SOURCE: Loud Buzzing Sound
This may be a power supply failure, and or a short in the output stage, and in the drivers for the output stage.
This is not a repair you can do at home unless you have a lot of experience in troubshooting and analysing problems in power amplifier equipment.
Jerry G.
Posted on May 04, 2008
SOURCE: Poping in speakers
Same issue with my AVR-589...2-15 minutes after sound is playing (via TV or DVD). I checked all wires and speakers. Even reconfigured to audio only (analog) coming in, same issue. Put my old Denon receiver in and the problem disappears...possible overheating issue with this new unit?
Posted on Aug 28, 2008
Bappa170873
  • 505 Answers
SOURCE: Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Posted on Oct 17, 2008
I am having problems with my speakers in n my vehicle. Can you make any suggestions?
Sounds like u may have a loose or poorly connected speaker wire.. some times installers use electrical tape witch can come off or cause issues..I would check all speakers independently withe the balance and fade options on the deck, then find the ones affected and then check wiring to them , if all wiring connections are good, then u may have blown a speaker.. if you had brand new speakers install you could have blown the voice coil by amplifying the volume too loud too fast...
Most speakers have a Break-in Point.. meaning not to put speakers at max volume for the first few days..
Jun 27, 2016 | 2004 Hyundai XG350
Hey I have an hdmx jam xt extreme wireless Bluetooth speaker & after a few seconds after I have paired with mine or a friends phone the music will stop playing, this sometimes doesn't happen if the volume...
To me it looks as if the battery is not charged ok. I'm not sure if you can monitor the battery voltage, but if you could, and you saw the voltage drop bellow a certain voltage and the speaker stopped there, and you could repeat this that would be the case. But perhaps you just charge the battery and discharge it a few times, before you panic. Some batteries only start working with full power after a few charges.
Jun 23, 2014 | Radio Communications
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
Wotcha, i've just taken amp out of storage, has'nt been used for a while cant get volume to work properly the sound goes from speaker to speaker and up and down in volume whilst crackeling a lot as...
One way of proving it ISN'T the amp circuitry is to remove the pre-main jumpers and jack in a source that has its own volume control (or try a CD that starts really low) because this bypasses ALL the amps controls. If it sounds ok (albeit LOUD) I'd suspect oxidized contacts on the controls. Turn it off and vigorously operate all controls a zillion times to wear through it. In mosty cases it's the unused controls that fail because they never get wiped. Maybe a shot of contact cleaner on those you can access.
http://www.overload.it/supporto/643/manuali/NAD-C350.pdf
Oct 15, 2011 | NAD C350 2-Channel Amplifier
Receiver fading in and out.
I want to think about this for awhile but first I want to caution you to NEVER turn the volume all the way up and then place your ears near the speakers for diagnosis of an unknown problem. If you inadvertently affect it to come back you can kiss your speakers (and maybe your ears) goodbye.
I'd agree that it is none of your hardware if it affects all inputs, two receivers and multiple speakers.
This sounds like a good one.
The simplest source to use for further trouble-shooting would be FM as it has no external connections, and it's vanilla stereo. Keep It Simple.
"Power bars"? Do you mean like a power strip with multiple outlets and maybe some kind of surge protection? Pare the system down to its most basic form - receiver, front speakers, one power source direct from the wall. What happens? Add components and complexity until the problem returns. Good luck.
Jan 22, 2010 | Audio Players & Recorders
2001 Buick Regal, Rear speakers not working properly
Well the voice coils in the speakers may be fried, or on their way out. Has anyone been simply turning it up too loud, or too bassy, or at obscene levels.
May 27, 2009 | 2001 Buick Regal
One speaker works all the time the others only sometimes
Could be intermittant wiring issue or the speaker itself.
If you have another spare car speaker you can hook up temporarily, I'd start there. Disconnect one of your "bad" speakers and hook up a known good one. If the temp. speaker works OK all the time, then you know you wiring is okay.
Let me know if more ?s!
Mar 22, 2009 | 1996 Chevrolet Cavalier
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
At high volume sound shuts off, subs still work
You most likely have a shorted or damaged speaker, which is causing the internal amp chip to shut down (but does not affect the preamp outputs). A test you can do is to fade to one speaker at a time and turn it up to se if it shuts down. Repeat with each speaker until you find the one that causes the fault. Then replace it.
Dec 08, 2007 | Pioneer DEH-2100 CD Player
 Grubhead
Grubhead
