Question about Dremel Tools & Hardware - Others
There is only one half ok video about how to attach an attachment on a WEN flexible shaft. I did my best to follow it, I have it installed but the bit will not turn.
I need to do my birds' toenails and being poked since we are overdue because I can't find my other rotary... the one that starts with a D. Would it be easier to put the bit into the machine instead of the shaft for just this time. Thank you. Not that I know how to do that either.
  • 2712 Answers
SOURCE: Rotary tools Attachments
Flex Shaft, Sanding Disks, Polishing Pads, Metal Blades, Wire Brushes, Abrasive Brushes.
Posted on Aug 27, 2008
rowdy45176
  • 2176 Answers
SOURCE: using the flex shaft attachement.
I dont think it should get that hot. Dremel has a program for the 225 Flex Shaft and for 17.90 they will exchange it for you. Send it to DREMEL 4631 E. Sunny Dunes Rd. Palm Springs, CA 92264. Their phone number is 1-800-275-2052. Hope this helps. Dave
Posted on Dec 24, 2008
t_vinson57
  • 58 Answers
SOURCE: Gear attached to moter is broken
This is how a got my gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
  • 376 Answers
SOURCE: Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
Posted on May 25, 2009
  • 81 Answers
SOURCE: Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Posted on Jun 17, 2009
How do you attach flexible extension to the main unit?
usually you need to remove the front collar of the main unit, it usually just screws off. Don't lose it as you will need to replace it when you remove the flexible unit. You then insert the shaft into the collett and tighten it then thread the outside of the flexible shaft onto where you disconnected the the front collar. You do not state model so I cannot give you exact instructions
Sep 14, 2015 | Tools & Hardware - Others
I have a Poulan 810EPT electric motor that has worked great but now my attachments won't slip and lock into the end of the shaft. Can't see any obstruction except maybe the flexible cable on the...
This sounds like the flexible drive shaft inside of the main shaft has a stripped ferrule. In order for you to fix this, you will have to take the main shaft off of the motor housing and pull the flexible shaft out of the inside. The replacement part number is 530056570 and should be about $12 to replace. Call the number on the unit to order replacement parts or go to your local sears.
Aug 27, 2011 | Poulan Garden
How to replace the lower flexible shaft
Hi enriquemon,
To remove the drive shaft, loosen the clamp that is just above the protective shield and remove the set screw attaching the drive shaft tube to the trimmer housing. Remove the drive shaft and if you want clean and inspect for damage. You are installing a new one so it is not an issue. Coat the shaft with a high quality, multipurpose lithium grease. Make sure the ends of the shaft are properly located in the drive adapters when assembling. Depending on the amount of time it is used, the drive shaft should be cleaned and greased every year or two. I hope this is helpful to you. Any questions welcome. All the best and good luck.
Feb 19, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Talon electric line trimmer AT2307A. When I press the start button, the bottom attachment with the nylon line does not spin even though the motor is running.
Halfway down the shaft of the line trimmer, you can detach the line trimmer attachment ( this in so you can fit a lawn edger attachment if need be). Unclip the line trimmer at that halfway point and the start the motor and see if that rod inside the shaft is spining, if so, reattach the line trimmer attachment and see if the nylon line spins, if so, it wasnt attached correctly, if not, then there a break in the flexible rod going to the trimmer head, most likely at the bend.
Dec 29, 2010 | Garden
How much does it cost to repair a cv axle
The best option isn't to repair it, but get a rebuilt half shaft. Otherwise you run the risk of the other CV falling apart right after the new one starts putting pressure on it's joint. Never buy a new CV all by itself and try installing it to the half shaft, thats just too much work for too little gain. Most half shafts are pretty cheap and come ready to go with 2 brand new CV joints attached and ready to install.
Mar 14, 2010 | 1998 Volkswagen Jetta
Need a replacement flexible shaft attachment . when i took flexible shaft off a piece appr. 2" long pulled out of shaft
The part you need is available at most Lowes and Home Depot stores. You can also order it online directly from Dremel. Ckeck your manual for the part number.
Mar 05, 2010 | Dremel 400 Xpr Rotary Tool
Flex shaft attachment
Takes an adapter to screw onto the nose of the Dremel. The shaft itself is gripped by the correct size collet tightened as you would any bit.
Mar 02, 2010 | Dremel 225 Multipro Flex - Shaft...
We the multi-functional mixer attachments but now unable to get shredder to attach correctly
Remove the shaft an cutter first and install the outside case of the shredder. Tighten thumb screw. You may have to lift up on a lever that runs in a groove in the shaft to remove the shaft.
Next install the shaft with cutter attached. Lube the shaft with tiny bit of mineral oil or food safe grease. Lift the lever mentioned above and rotate till the shaft seats and then drop the lever and make sure it is engaged.
Feb 03, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Flexible shaft not working all-in-one rotary tool
check and see if you have the right collet insert in the chuck if it is too big it wont lock the shaft. does the chuck turn? if so your collet is not locking the flex shaft
Jul 09, 2009 | Dremel 400 Series Xpr Rotary Tool Kit with...
Thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Tools & Hardware - Others Logo
46 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
