How to return the lamp to get another one - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 51,189 Answers
Usually if installed there is no returning electronic parts
Posted on Jan 04, 2017
I need instructions on how to replace the lamp in the promethean prm-25 projector
Make sure projector is unplugged and cooled down, lamp can be very hot
Remove the cover over lamp area
There are 3 screws in lamp unit (they have little arrows that point to them even) or check against new lamp to make sure you take out the correct ones
Pull straight up, place new lamp in securely and screw back down (screws are attached to each lamp set)
Place cover back over lamp area and screw closed
Reset lamp hours by hooking up your computer to board
Get to lamp reset screen
Press down up left right arrows in sequence then press return button in middle
Jan 26, 2013 | Promethean Board Lamp for PROMETHEAN PRM25...
No sound or picture on jvc 52fa97
If lamp is bad set will detect that (or other issues) and kill all functions=not unusual to have no sound if lamp is bad.
Apr 15, 2012 | JVC HD-52FA97 HDTV
How do I make my interior lights turn off without taking out the fuse?
The trigger for light is a return GROUND which goes to all the door switches and the light dome switch. so if there is a short on the holder or on the lamp return wire this willoveride the switches and the lamp will stay lit.
So remove the dome light and check holder and return wire to switches for short.
Oct 15, 2011 | 2002 GMC Yukon XL
SOUND WORKS BUT SCREEN STAYS BLANK/BLACK AND LAMP LIGHT STAYS ON CONSTANTLY I CHANGED THE LAMP AND THE RED LAMP LIGHT STAYS ON AND PICTURE STILL BLANK
Replacing lamps can be tricky. Make sure that the lamp is securely installed and you have returned all screws to their same position. Double check latches and doors; if they are not secured properly then the lamp sensor will not recognize that the lamp has been changed. Also, refer to your manual for lamp replacement procedure you may be required to press a series of buttons on the remote or TV control panel to reset the lamp.
Mar 03, 2011 | Philips 60PL9200D Projection Televisions
I replaced the bulb on my optoma ep1691 projector but the picture still goes out and the red lamp light lights up. I reset and confirmed the reset via the menu. How can I resolve this issue?
It seems OEM lamp that was replaced in projector is not good, please return this lamp and ask another lamp to solve projector problem. Projector seems fine and has no issue, it is replacement low priced lamp that is causing problem.
I would recommend to buy original lamp from Optoma Support.
Thanks.
Mar 02, 2011 | Televison & Video
I need to know how to reset lamp timer please thank you
Hi ttwildman,
Plug the TV into the outlet. Press power button on the display. Next, press the Volume minus button on the display and, hold down the 0 button on the remote for 5 seconds. You should see on the display a message saying, "Lamp time was reset to zero, Return." Select appropriate entry on the remote to return to normal screen. If done right the lamp indicator light will go out. That is pretty much it. You can download the instruction here, "Panasonic PT-52LCX66." Additional information under can be optained by selecting, "View with PicLens." If you have any questions just post a comment and, I'll try respond quickly.
Jan 27, 2011 | Panasonic PT-52LCX66 Projection Television
Lamp light is blinking on my sony 42 grand wega rear production tv...how do you fix install a new lamp
first step.remove the screw and lamp door cover at the right side of your TV . After removing the screw and lamp door cover, you will see the lamp cover (it is color black with a handle at the bottom).then turn the knob/handle of the lamp cover on counter clockwise direction to remove it. Then you will see the lamp of your projection TV. Remove the old lamp and replace it with a new one..Make sure that the lamp is properly installed, the return the lamp cover and turn the knob on clockwise direction to lock it up,then return the cover ,screw and its done...
Sep 18, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hello. my screen goes black for 4-5 seconds like the power is turned off, but picture returns.
replace the lamp. This happens when the lamp is going bad. It also happens from other things but the lamp is the easiest to replace.
Feb 01, 2010 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-55A2020 picture goes blank then returns
This sounds like the ballast for the lamp is going. The ballast sparks the lamp, and if it starts to go, there's not enough current to keep the lamp sparked. Thus it starts to fail: it's the same principle as a fluorescent lamp fixture. Ballasts are available at any service depot, but they're fairly expensive, and perhaps prohibitively so; you may want to look at replacing the monitor itself.
Jan 07, 2009 | Sony KDS55A2000 55" HDTV
We keep losing sound and picture on our TV
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
