Dlp lamp return
Dlp lamp for tv return
3 Suggested Answers
pazman
  • 81 Answers
SOURCE: DLP Lamp Replacement
in the rear their is a section were you can uncrew and replace the lamp. be sure that its unplug from the ac outlet and you wear a glove so you wont touch the lamp.
Posted on Apr 01, 2008
SOURCE: How to reset the DLP TV Lamp Counter
Press and HOLD the ENTER (or OK) button on the TV
Press and HOLD the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
Let go of the REMOTE button first, then release the button on the TV
We suggest writing your lamp hours on a peice of masking tape and taping it to the back the TV for future reference.
To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter For certain models, you might have to tweak these steps slightly…offer your inputs!
Posted on May 17, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
My tv mitsubishi wd-60735 turns on for about 2 min. then shuts off and red lamp light turns on,,,The lamp is only 3 months old.. Do I just need to replace bulb again or is it something else???
Don't know if this applys to you but if you have purchased anything but Osram or Philips replacement lamp for your DLP tv then this is probably your problem.. The generic is VERY tempting in this recession but in this case generic is poison to your dlp tv... i have a Mitsubishi 60735 and went thru 2 generic bulbs when my tv kept shutting down on it's own and the lights on front would flash, i could cut it back on for 10 minutes then flicker and shut down again ..well since the bulb was new i thought it may be defective so i got is exchanged for another one ... after all of the post i have seen how much repairs were going to cost on dlp sets no matter what the problem was ..i was ready to chunk the tv out the door when the second lamp was doing the same thing.....!! well a last ditch effort to save my tv before i trashed it or taking it apart to dissect it.. was to buy a brandname lamp ... in my case i purchased a Philips ..it cost twice as much =/ ..i could just return it if it didn't work.. well it was the generic lamps that was causing trouble.. the brandname worked perfectly .. i am just glad the generic lamp didn't do any damage to my TV!!! I have done further research on the generic lamps and realized that the damage it could have done was not worth the money i saved when i purchesed it... Generic is a great deal In some cases (household cleaners, etc..) but in this case GET THE NAME BRAND!!!! the only name brands i know of for these lamps are Philips or Osram/Sylvania.. hope this helps others from this headache. Do your research don't by generic lamp replacements, your DLP set cost to much to risk it.
Jul 20, 2011 | Mitsubishi WD-60735 Projection Television
Hi i want to ask about a lamp that related to thomson tv thomson 61 dsz 644 dlp hd tv lamp what is its price ?
http://cgi.ebay.com/LAMP-THOMSON-SCENIUM-61DSZ644-RP-HD-DLP-TV-/270697798709?pt=LH_DefaultDomain_205&hash=item3f06d89c35
Mar 09, 2011 | Thomson 61DSZ644 Rear Projection Lamp...
The picture is not bright in a light-filled room. Will a change of DLP lamp help? Are there different lamps that will improve picture quality?
Yes.Depend how old is ur DLP tv,the Projection Lamp only a light source,mostly depended on the Light projection Engine itself.Get the original RCA DLP lamp or same lamp model now inside the tv,will help and work best for ur tv.Just don't get generic DLP tvs lamp,it cheaper poorer quality.
Dec 17, 2010 | RCA HD61LPW167 61" HDTV
Can I replace the DLP lamp myself or do I really need a repair technician to do this?
U can replaced the DLP tv projection Lamp ur self.Try website like YouTube.com.Type in Mitsubishi DLP tv projection lamp replacement.There will be a tutoring video by somebody,replacing the DLP tv projection lamp.Tries websites like Ebay.com,Partstore.com to buy a new DLP tv projection lamp.
Oct 15, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
DLP TV Samsung HLP4674w No Picture
If you hear a ticking and or buzzing sound as it is trying to start up then most likely the replacement lamp is bad. Take it out and reseat it one more time to see what happens. The noise you hear is the ballast attempting to fire the lamp up.
Nov 30, 2007 | Samsung HLP4674W 46" Rear Projection HDTV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
