Question about Refrigerators
My Holiday Refrigerator NT156M is leaking from the top of the fridge part. How can I stop this?
  • Refrigerators Master
  • 10,045 Answers
Depends on what is leaking. Can you tell us what it is that is leaking?
Posted on Jan 04, 2017
2 Suggested Answers
  • 121 Answers
SOURCE: Holiday Refrigerator NT156M stopped working.
check to see if stuck in defrost locate timer and advance it
Posted on Apr 17, 2009
I operated the "Holiday Mode" button on my Model WSE6100WA fridge. After returning the temperature display etc does not illuminate so I can't operate any temperature controls
The eco/vacation mode only exits when the door is opened if it was started automatically by the refrigerator. Since you pressed the eco button, you'd have to press the eco/holiday button until the display shows no icon for the feature.
How long did you have the power off to the refrigerator? Try pulling the plug for a 5 minute power outage. If that doesn't solve the problem, I suspect your appliance may have been damaged by a power fluctuation while you were away. Without additional information, I can't tell if only the display panel is damaged or if something else is wrong. The parts diagrams for the refrigerator are available here: .
I hope this helps.
Mar 10, 2014 | Refrigerators
Refrigerator(top section) has completely stopped working. Freezer still works and makes ice.This is the christmas holiday. We have company from out of state here and really need help. All food is getting...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
For a quick fix in this situation just thaw the coils out with a hairdryer.
Dec 26, 2010 | Maytag Refrigerators
Leaking water into fridge from freezer need to stop it
It may be that your ice maker is leaking, or is plugged up, or you may need to vacum the back (coils) of the refrigerator.
Aug 19, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator leaking water in refrigerator section. sometimes stops, comes from back top area in center
try cleaning out vent pipe...should stop build up of water inside fridge...
Feb 09, 2010 | Refrigerators
Apr 17, 2009 | Frigidaire FRT21P5A Top Freezer...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
