Question about Ford Garden
I have a ford tractor with model number BS414K, can you tell me the year and model such as 2910 or 3910
What year is my Ford tractor? Tractor #C671576, Model KA214C,Unit#1F1B and Engine #1D21A
There is a wed site you google it tells you the year of your tractor . put in what year is my ford tractor and go from there
Mar 05, 2018 | Ford Garden
I can't read the number on my ford 9N there is a number on the generator that is 9N 10000 can you tell me approximately when my tractor was made
IF you can find the number but can't read it head-on, get a bright flashlite and shine it across the SN sideways close to the metal kind of glancing and see if it shows up.
The bad news is 9N designates a model between 1939-1942. No definite year is usually assigned to these Ford tractors.
Here's an article explaining it all. It's pretty interesting.
SERIES FORD TRACTOR SERIAL NUMBERS AND MODEL IDENTIFICATION
Sep 25, 2017 | Ford Garden
FIND OUT THE MODEL OF A FORD TRACTOR WITH SERIAL NUMBER C586565. INDUSTRIAL STYLE TRACTOR
3600 series . Year is 1978. Need the production numbers above the serial number for more detail.
Dec 23, 2016 | Ford Garden
What year is my 861 ford tractor with serial number 113333
look on the engine block for the N number then google ford tractors it will help you find the year .
Oct 30, 2016 | Ford Garden
I have a ford tractor with the model number 640 and serial number 11377 can you tell me any history about this tractor
Yours was made in 1955. If you go to www.yesterdaystractors.com you can see most of the original spec and history
Aug 15, 2016 | Ford Garden
What year is my mower
The serial number alone is not enough to determine the year unless you also include the maker and the model number. Even then it may not be possible, but without that information there is not enough criteria to figure it out.
For example, if the tractor was made by Sears then you probably could narrow down the year based upon the years of production of that particular model at Sears.
Sometimes the year is embedded in the serial number, but the algorithm for determining that is based upon the maker and the model...there is no universal serial number to model year conversion... And in some cases the serial number has nothing to do with the model year... It literally can be a randomized number that's ensured/verified to be unique... However in that case the company may have a database that they can look it up and tell you.
my recommendation is to call the company that manufactured it and give them the model number and the serial number and they will probably be able to tell you... If they can't, chances are there is no easy way to figure it out.
May 23, 2016 | Garden
Can you tell me the year a Ford New Holland tractor/ backhoe serial number c642774 was manufactured? Also do you have a part number for the thrust bearing for this model tractor? Thank you!
Hi Susan:
It is unlikely that a FIXYA person would have the bearing that you are looking for, However, I would suggest that if you were to use Google to locate the dealer or service rep in your area (or even the nearest farm equipment dealer), you will be able to get the information that you are looking for.
Here is a link that will allow you to do a parts search.
http://partstore.agriculture.newholland.com/us/parts-search.html#epc::home
Cheers
Mar 04, 2016 | Garden
Garden Logo
44 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
